Fane Sovereign 12-250TC project measurements
Rednaxela
NL
One edge I personally see that the fifteens do have over the twelves would be bass extension.
Here’s a project that tries to actively take advantage of this aspect.
Most others (including me at the time) seem to start out in a way that at one point they’re gonna think about adding bass drivers.
P
ppataki
Budapest
One more advantage of the 15s that I would add is that they have 60% more cone surface area vs that of the 12s
530 sqcm vs 855 sqcm (each)
So it will move much more air in the room and I do believe that it will hence provide more impact and more presence (further contributing to that 'live' feeling)
You will physically feel the air pressure
Rednaxela
NL
All right, thanks.
So all else equal you’ll find your twelves having to go back and forth a bit further to produce the same impact as your fifteens. Which you may or may not notice. At the expense of benefits to the twelves you may or may not notice either.
Only one way to find out. :) Time to start building man!
P
ppataki
Budapest
Well....as mentioned above, my current system has just been finished a few months ago so it would be a bit odd to replace it already :)
But definitely I am planning to do that - just need to figure out when exactly. Some time in the coming 9 months it will be done for sure
In the meantime I need to finish this project + this project........ :D
jamescarter1982
I need to get these back out of storage and have a play with them . thanks op for posting this thread good to see other people out there interested in these drivers
Rednaxela
NL
For what it’s worth, here is another opinion on the twelves vs. the fifteens.
Edit: opinions galore on line of course but because this one was posted on ASR I thought I’d link to it here as well.
jamescarter1982
One of my friends has built a pair of floorstanding loudspeakers using 12" Fane 12-250TC fullrange drivers. I am posting this on his behalf and with his permission.
Cabinet is sealed with the below parameters:
Made of 19mm baltic birch plywood using internal bracing (unfortunately I do not currently have the pictures of the inside of the cabinet)
The final result looks like this:
The objective measurements will follow below, also with the mdat file attached
Subjectively the sound is typcial to fullrange drivers:
- very 'live sound', you feel like you could talk to the musicians in the room
- extremely holographic presentation, each instrument has its own 3D space
- extremely precise soundstage
- very heavy DSP is needed to flatten the response (all the listenings were done with DSP - don't even try these without it, you will cry :))
Now the measurements:
FR with zero correction (L/R channels)
1/12 smoothing
FR with full correction
Corrections were done using a combination of 'pre-EQ' low and high shelves followed by parametric EQ-ing using CraveEQ (Transparent Phase Mode) based on REW generated filters and then CurveEQ for further flattening of the response
Also tried Dirac Live but the resulting sound became a bit dull and lifeless compared to the above method
Now when listening to music using the above curves the bass was not there......
After measuring the LR channels combined the reason for that became apparent:
There is a huge cancellation dip between 50 and 100Hz when the two speakers are measured together
Normally we shall not touch this since unwanted ringing might occur if we try to compensate but we had no choice and applied some further filters to correct the summed response which looks like this after correction:
By listening we could not notice excessive ringing, I suspect due to the size of the room (70 sqm)
Bass came to life and the 'order of the world' is restored :)
Distortion looks OK too in my opinion:
Step response is pretty nice too:
Wavelet diagram:
Overall my friend is extremely happy with the results!
I cannot upload the measurement since it is too big but here is the link to it:
I would encourage anybody to try a big fullrange driver (with adequate DSP) - the listening experience is worth the effort
could you tell me is this considered a low distortion loudspeaker driver ive read the distortion to be 0.843% is that correct please ? .
many thanks
P
ppataki
Budapest
many thanks
If you take a look at the distortion graph you will see that above 100Hz it is kept in check; however below 100Hz it has peaks up to 5%
This is inevitable when you compensate for the low end of sealed cabinets (either with low shelf or Linkwitz Transform filters)
Also note that when there is a dip in the frequency graph that translates into elevated distortion in the distortion graph
I can tell you that this is still totally inaudible
jamescarter1982
OK thankyou so above 100hz were down around 0.5 percent .I understand about raising distortion in the bass by forcing the driver to work harder in a sealed cabinet . that could be solved by using a separate bass driver if you really wanted .
is the 0.5 above 100hz low for a speaker driver I'm trying to correlate the relaxed unforced sound I hear with the distortion measurements if that's possible
P
ppataki
Budapest
Correct, but I deliberately will not do that since it would defeat the concept of a 1-way system
In my opinion yes, 0.5% above 100Hz can be considered a good value
See the distortion graph for my current MCLA system at 75dB:
I am totally not worried about this :) - it sounds awesome
This is the distortion graph of a Nubert nuBox 483 at 75dB:
Does not look much better above 100Hz (and it is a 2-way speaker)
Finally, the distortion graph of this project at 75dB:
As you rightly pointed out, using a sub would reduce the distortion, but again, I personally cannot hear those ~5% values for the other systems I quoted
jamescarter1982
thankyou all interesting reading . have you ever tried removing the low bass using eq to see if that had any effect on the distortion of the higher frequencies my theory would be the driver would be moving less if not asked to produce bass so then might have even lower distortion .
these graphs do make me think we might be living with speakers that have a lot more distortion and are either used to it or unable to hear it
P
ppataki
Budapest
Yes I did that
I applied a 24dB/oct. high-pass filter at 23Hz to my MCLA system
See the distortion graphs overlayed (the one with the cut highlighted)
Apparently there is no impact on the higher frequencies
Even if I zoom in:
jamescarter1982
Yes I did that
Even if I zoom in:
thankyou I think it would depend on frequency cut and also level . and maybe vary from speaker to speaker . my idea would be to cut around 100hz or something like that . hoe do you perform these tests is it a frequency sweep with a mic close to the speaker cone can you do these tests on a budget I'd be jnsterested to do some myself
jamescarter1982
Yes I did that
Even if I zoom in:
would a line array with these fane 12inch full range work the cone would be be barely moving to produce huge volume I would expect
P
ppataki
Budapest
Once my Topping DM7 arrives I will do that cut at 100Hz to see what happens
I always perform these measurements at the MLP (main listening position), umik-1 at 90 degrees, sweep measurement
