@coolajami except it also has huge reductions in noise/distortion and many multiples of the power. Amir measured the K5 Pro at 990mW @32Ω.
Balanced offers around 3x the power, this does substantially higher power than the single ended, either on this or the K5 Pro. You may not need that, but it's a key difference. It's also convenient if you have headphones already wired for balanced, this would be perfect for me for a secondary setup. An all-in-one with much better noise/distortion numbers, a choice of single ended or balanced out, and 3-4W @32Ω for $199 is pretty compelling. It's a big step up from the K5 Pro in many ways while keeping the same form factor.
You may not need any of this, but you could point to plenty of much more expensive devices that do similar or even less. For that matter even Fiio's own K9 has apparently lower power than this does.
Given the K5 Pro is $199 though, I suspect this is a translation of the Chinese price and it will cost more than this in the West. Chinese domestic prices for most Chinese HiFi stuff is much lower than the Western price.
EDIT: Fiio confirmed on Head-Fi the US price will be $199. That's remarkable, arguably class redefining, it has roughly double the power of the Topping DX3 Pro+, and a choice of single ended or balanced outputs. Although Fiio say the lower 2W power spec is for "output power for long time stable working mode".
If your priority isn't that but is having the optical output, then sure, get something with an optical output.
