Finally, music we can buy in 768 khz sampling rates.
voodooless
Netherlands
I vote for Dr. Who’s sonic screwdriver. This event was so profound that he just could not miss it.
MakeMineVinyl
Santa Fe, NM
I had a Studer A77 Mk II with 15 ips capability. It had been refurbed just before I got it around 1990. Very similar to the A80 actually. Spec'd at SN of 66 db which I thought odd. My measures of it ( I didn't have as good a way then as now of measuring such) were around the 60 db mark.
Tape machine signal to noise specs have always been "cheated" in that they are taken at the 3% THD point, which is usually about 6dB above the nominal operating point of 185nWb/m or other nominal operating points dictated by the ability of the tape. You then add +4dB for the nominal output level of the machine (or whatever level the machine uses above 0dBm) to the added 6dB which comes out to 10dB added to the measured noise from the machine. So a 55dB measured machine would be advertised as a 65dB signal to noise ratio machine.
Pretty slimy overall, but that's the way its always been done from the first professional Ampexes.
Screenshot 2022-01-03 at 07-48-47 Ampex 354 Manual (Page 58 of 76) ManualsLib.png
Sound Liaison
They are clearly deaf, otherwise they would have spotted the 150 kHz sound and fixed it in mastering :facepalm:. How can you not hear this…;)
I don't know if I will be able to answer all of you but I'll try to look at this thread now and then in my spare time.
Our hearing was fine last time we checked:).
At such a high sample rate editing is not possible , at least I am not aware of any software that can do so, so it was not possible to "fix'' the 150kHz peak generated somewhere in the analog chain , probably the Studer. It's a straight one to one copy from the tape.
If you do "voodooless'' please let us know.
We have made one track available for free purely as a service.
Blumlein 88
Blumlein 88
Does 768 kHz give you anything you cannot get with DXD given a tape source?
voodooless
Netherlands
Adobe Audition opens the file just fine and let's me do a notch filter at 150 kHz without problems:
voodooless
Netherlands
@Sound Liaison , would you permit to publish a redbook downsample so people can actually compare your version to an inferior version, like with an ABX tool?
Sound Liaison
Sure we could do this kind of edit but now we have a ''hole' instead of a peak. I should like to have the possibillity to smooth out the peak so we would have a straight line.
voodooless
Netherlands
Sure, just tweak the gain until it’s okay.
antcollinet
UK/Cheshire
I have a better idea, low-pass it at 40 kHz or so, thus getting rid of all that useless noise. Then you could also drop the sample rate to 96 kHz and save lots of space.
What is wrong with a low pass at 20kHz and 44.1k samples?
Sound Liaison
I have the impression that it's a bit rounder. It seems to be a bit closer to the sound straight from the Studer. It is a very slight improvement.
We still have to see if we will continue having such big files on sale in the future as the cost of having such big files ready in the cloud could be a bit too heavy. But that is also the reason we have asked for feedback from our listeners, which so far have been very possitive.
Sound Liaison
Sound Liaison
Nothing wrong with 16/44.1 if you like it better. The Redbook CD version and 44.1 download will be available at
Carmen Gomes Inc's BandCamp website .
there you can buy all the albums she has recorded for our label in CD or mp3 format. It's a great way to support her directly in these trying times.
All procedings at BandCamp goes straight to the artist.
voodooless
Netherlands
Why stop there? Make it a 20/48 can call it a day… hell, I proposed to ABX with 16/44.1 ;)
I guess we could make the appropriate samples from the source file and offer them for ABX. It doesn’t need to be the complete file, 20 to 30 seconds should be plenty. We probably would not need permission from the label/artist, since for research this would fall under fair use. But alway better to ask first anyway :). Also the mods might have something to say about that as well, so @BDWoody?
Sound Liaison
antcollinet
UK/Cheshire
Nothing at all, though that would lose some non-noise content. Not that the difference would be audible.
Aye! My dog** might not appreciate it as much.
** If I had a dog. :cool:
