Fixed my tweeter, beyond happy
gags11
Today was one of those gratifying days. I was doing some measurements, specifically looking at the tweeter output of my active speakers. Noticed my left channel had distortion way higher than the right channel (see graphs below). What the heck!
So I got these vintage Pioneer / TAD beryllium ribbon tweeters that I had purchased from Japan. Started examining the tweeter. It is old, let me say, so does not look pretty. You got the beryllium leaf and a metal thin mesh in front. Someone had pushed the grill in. Could it have touch the leaf and cause distortion?
I disassembled the unit, straightened the from mesh grill. Viola, distortion down to the level seen in my right channel. I thought the tweeter was bad and did not have any real hopes. But now I am so happy, finding a bit of joy in these horrible times..
Figure 1. Left channel distortion compared to right. Right has much lower distortion. Tweeter response 3khz high pass active filter. About 93db spl at 1 meter.
Figure 2. Same as above with fixed left tweeter. Impressive improvement in distortion.
Figure 3. Frequency response, distortion and level before and after the fix. Left tweeter only.
Doodski
So I got these vintage Pioneer / TAD beryllium Rubin tweeters that I had purchased from Japan. Started examining the tweeter. It is old, let me say, so does not look pretty. You got the beryllium leaf and a metal thin mesh in front. Someone had pushed the grill in. Could it have touch the leaf and cause distortion?
Nice repair job! :D Diagnosed issue, confirmed issue, confirmed fault, repaired unit and then confirmed fix. Perfect.
McFly
NZ
Wow! Nice. And nice repair. May I ask, before you started did you suspect you could hear an issue/something off? Or were you just measuring out of curiosity?
G
gags11
I really did not have a clue or hear a difference. I was just tuning my crossover, levels, etc. It was just luck. If I did not measure, I would have never known.
Laserjock
Texas Coastal
Beryllium is supposed to be very toxic if any particles are breathed in.
Probably ok but I would have taken extra precautions.
We use it in our beam steering mirrors.
G
gags11
Yes, beryllium is really toxic. I think one of the reasons it is not used as much now. I was as careful as I could be.
A800
Let it Be.
