Focal Clear Review (headphone)
Peterinvan
Hello,
I'm looking for a amp for my Clears. I actually listen out of my laptop and it's pretty nice but I think I can improve my listening : i don't know the world of hifi so...i just want to discover, learn and enjoy :
  • Low volume listening
  • All kind of musics
  • Maybe a little bit more of soundstage
  • Maybe a little bit warmer
  • Small device or elegant (the headphones are in my living room...which belongs to my wife).
  • <300$.
Thanks for your suggestions !
I am enjoying my new FiiO K7 (with a LPS). Drives my Elegias (and other phones) with ease. Should meet all your requirements above. :)
Bibo
Germany
I own my Clears for more than 6 years now, they are still my daily drivers. I only switch to other headphones (closed back or even NC) if I have to, because family live takes its toll.
So after 6, years, what are my key points:
Pros:
- They are still the best sounding headphones I ever heard. These are de facto the only headphones, that sound 100% "right" for me.
- They used to be very comfortable. This has changed somewhat, see cons.
- They do not clip at my listening volume.
Cons:
- Earpads wear off very fast and they are laughably expensive (230€ a pair). Luckily you can get these from China for 12€ by now, probably from the same factory as there is no noticable difference in quality.
- Cables are too stiff and quality is poor. The balanced cable broke after only two months of usage. Could not RMA it, because I did not not use it from the beginning (I did not have a balanced amp then). Official replacement is 230€ too. Ridiculous.
- The headband snapped recently. This seems to be a common problem, because the headbands are somewhat overengineered. Sourced a replacement headband from China for 50€ that does the job, but comfort degraded a bit (see above).
So was the investment of 1499€ in 2018 worth it for me? Definetely yes, because I had that money and I love my Clears for their sound and there is no alternative for me. But I do not like to be scammed. And the price for replacement pads and cables is a scam. Period. And build quality is disappointing too for that price.
Rayman30
Pros:
Cons:
I also own Clear OG, they are tuned in a certain way that makes them sound what I would describe as "Light on their feet" I enjoy them the way they are out of the box. I got rid of the stock cable for a $65 Periapt cable a while back. But when I want more meat on the bones, I grab the LCD-X.
