Focal Twin6 Be Studio Monitor Review
hardisj
Reviewer
North Alabama
As always, this is a direct copy/paste from my website so some formatting may not transfer correctly here. You are welcome to go directly to my site to read the review:
https://www.erinsaudiocorner.com/loudspeakers/focal_twin6be/
Also, I have included a link to my YouTube review below.
  • Wednesday, Apr 7, 2021
However, for those who want more - a detailed explanation of the objective performance, and my subjective evaluation (what I heard, what I liked, etc.) - please watch the below video where I go more in-depth.
Information and Photos
The Focal Twin6 Be is 2.5-way Studio Monitor. The below is from the manufacturer’s website:
The Twin6 Be is the best seller of the Focal Professional range and the most versatile work tool of the SM6 line. It represents the only necessary solution for recording, mixing and mastering. The image precision, treble definition as well as midrange neutrality are at the heart of its reputation. The excellent articulation of the bass and midbass registers, even at very high sound levels, makes it an unavoidable reference for engineers who require absolute transparency. Furthermore, the design of the Twin6 Be permits a high SPL while at the same time offering a stable tonal balance. One of the two 6.5” woofers works in large band (midrange – bass) whereas the other reproduces from 40 to 150Hz. This creates a bass that preserves all the signal dynamics, without any masking effect in the midrange, thereby keeping all its neutrality and transparency. Additional control of the bass register is accomplished by fine-tuning on the control plate on the back of the Twin6 Be in order to obtain a perfect mirror configuration with its mate. The Twin6 Be can be installed vertically or horizontally to respond to the space requirements of each studio.
MSRP for the single speaker is approximately $2200 USD and $4400 USD for a pair.
And here are some specs, again from the manufacturer’s website:
All data collected using Klippel’s Near-Field Scanner. The Near-Field-Scanner 3D (NFS) offers a fully automated acoustic measurement of direct sound radiated from the source under test. The radiated sound is determined in any desired distance and angle in the 3D space outside the scanning surface. Directivity, sound power, SPL response and many more key figures are obtained for any kind of loudspeaker and audio system in near field applications (e.g. studio monitors, mobile devices) as well as far field applications (e.g. professional audio systems). Utilizing a minimum of measurement points, a comprehensive data set is generated containing the loudspeaker’s high resolution, free field sound radiation in the near and far field.
For a detailed explanation of how the NFS works and the science behind it, please watch the below discussion with designer Christian Bellmann:
A picture of the setup in my garage:
Since this speaker is atypical - due to the offset tweeter - I want to make note of how the tests (objective and subjective) were conducted. Per the manufacturer’s manual:
The Solo6 Be and Twin6 Be are designed for near field monitoring and should be placed at a distance between 1 and 3 meters from the listener, pointing towards the listening position. They can be sitting on the console top or placed on appropriate stands. In any way it is recommended that the tweeter is at a height from the floor approximately equivalent to that of the listener’s ears. If required it can make sense to place the speakers upside down so that the previous rule is better fulfilled. By design the Twin6 Be’s are rather intended for a landscape orientation, though in some situations they could be positioned vertically. As seen in the earlier rear panel description, the Twin6 Be has a switch allowing to choose which drive unit is to reproduce the mid frequencies (see below) (fig. E). Consequently it will always be possible, as desirable, to configure the speakers in a “mirror” (ie symetrical) way (fig. F). As a general rule having the “midrange” driver on the inside of the cabinet results in better imaging.
With the above in mind, this test was conducted under the following conditions: The reference plane in this test is at the tweeter. The speaker was tested in the horizontal configuration. Focal recommends the midrange be placed at the “inside” of the cabinet. This speaker was tested in the “right” configuration meaning the midrange driver is placed on the left side of the cabinet (when laying horizontally). The negative horizontal axis goes left (toward the midrange). The positive horizontal axis goes right (toward the midwoofer). I have included a graphic illustrating this configuration in the appropriate results.
Note: The roll off rate of this speaker is sharp and therefore some noise was unavoidable at 25Hz which causes a spike in the response here. Ignore the response below 25Hz.
CTA-2034 / SPINORAMA:
Early Reflections Breakout:
Estimated In-Room Response:
Additional Measurements
“Globe” Plots
Vertical Polar (Globe) Plot:
Harmonic Distortion
Harmonic Distortion at 101dB @ 1m:
Near-Field Response
Nearfield response of individual drive units:
Focal%20Twin6%20Be%20--%20Nearfield%20Driver%20Measurements%20%28~15cm%20from%20drive%20units%29.png
Response Linearity (Compression and Enhancement)
The below graphic indicates just how much SPL is lost (compression) or gained (enhancement; usually due to distortion) when the speaker is played at higher output volumes referenced to 76dB at 1 meter.
In-Room Measurements from the Listening Position
Below is the actual measured in-room response (with no DSP correction). This is a spatial average taken over approximately 1 cubic foot. The speakers were placed approximately 1.2m from the front wall (not the cabinets; but the actual wall). The listening position varied but stayed within the recommended 1-3 meters from the speakers.
Black = Predicted In-Room Response from SPIN data
Blue = Actual In-Room Measured Response from Main Listening Position at 1.5 meters
Purple = Actual In-Room Measured Response from Main Listening Position at 2.5 meters
While the prediction in this test is close to the actual measured response, there is a fair bit more deviation than I typically see in my other tests. I think this is likely attributed to the fact that I measured in the nearfield (as these were designed to be listened to) in my living room. You can see in the below graphic that sitting closer to the speaker yields a higher level response in the high frequency region (blue, 1.5 meters) and when backing away (purple, 2.5 meters) the HF response comes down a bit. I think if I measured these speakers as I typically do the in-room result would have matched the prediction better. This is an example of where the speaker’s purpose (nearfield listening) should be considered when viewing data.
Tone Controls (High Frequency and Low Frequency)
These speakers come with a HF trim (±3dB) and LF trim (±6dB). I tested these and made the contours relative to 0dB as you can see in the below graphic. Basically, both sets of tone controls hinge around the 1kHz region.
Parting / Random Thoughts
  • Subjective listening was conducted at a few ranges, not exceeding 3 meters. Primarily, listening was done at about 1.5 meters. Subjective listening was conducted at 80-95dB at this distance.
  • I did not try listening at different off-axis angles as this is designed to be a studio monitor and it is not reasonable that this would be listened to off-axis. So, I cannot comment on loss of fidelity as the speaker is aimed differently or the listener moves side to side.
  • I did listen in both the horizontal and vertical configuration. I personally preferred the vertical configuration because I often felt I could hear the sound “pull” toward the midwoofer driver. I noticed this primarily in mono listening. When listening in stereo, this issue only arose when music was panned far left or right.
  • “Soft” in the 2-3kHz region (missing some background air in Depeche Mode’s Enjoy the Silence) (missing “ck” sound of “back” in Everybody Wants to Rule the World). Miss it sometimes.
  • Nice, controlled bass in Higher Love (but nothing below 50Hz to give the rumble). Great bass in Know Your Enemy.
  • Excellent midbass and midrange overall!
  • Great bass lines in Wrapped Around Your Finger.
  • Midrange becomes “shouty” in Doo Wop at the beginning at higher volumes. This is a pretty complex track that stresses the midrange as bass if the driver also is playing deep bass. In this case, I typically chalk up such issues as IMD, though I am currently not testing IMD for loudspeakers as the requirements to do so are beyond the time I have.
  • Free Fallin - incredible midrange detail.
  • What Lovers Do: effects in soundstage are all on the same z-axis plane, behind the speaker’s physical placement.
  • Awesome “pick” in Feel It Still.
  • Until it Breaks gave me goosebumps.
  • Be careful with volume. Easily get to 95dB in the nearfield without even realizing it. No distortion to signal that you need to turn it down.
  • When listening in mono easily tell the midrange/midwoofer split. Not so much with stereo unless panned.
  • Soundstage is about 2 feet outside of speakers and about 2 feet deep in center.
  • There is zero mechanical noise from these speakers (pops, over-excursion, vent noise) even at considerable volumes.
  • The on-axis response is really quite linear with the exception of the 2-3kHz dip. From the nearfield data, this seems to be due to a steep low-pass filter on the midrange. The roll off begins promptly at about 50Hz which is adequate, however, a subwoofer is obviously needed for extended bass.
  • Hiss: When the input sensitivity was switched to +4dBu there was no audible hiss at 1.5m and also barely noticeable with ear next to tweeter. At -10dBu hiss was noticeable from 0.5m.
I don’t have a lot of experience with dedicated monitors so I don’t want to get too excited but I have to say the midbass and midrange of these speakers is excellent. I haven’t heard such detailed midbass out of a speaker thus far. It really is incredibly impressive, dynamic and ‘sharp’ (in a good way). The highs, however, were the downside for me. I found the 2-3kHz region to be a bit “soft” which tended to make the presentation a bit “dull” as the attack of instruments just didn’t sound right. Also, I swear I heard sibilance which I would expect to see in the data around the 6-8kHz region, though, I am not seeing it. I wonder if this is simply the overall level because you can clearly see in the in-room measurements (taken nearfield) the high frequency response is tilted up the closer you are to the speaker. I did listen in the farfield at one point just to see how the overall presentation changed but I can’t honestly remember what my thoughts were about the high frequency region because I was more listening to see if the midbass and midrange got worse (they didn’t). I tried using the tone controls but - as you can see in the data - it isn’t specific enough to target just the high frequency region above 5kHz; instead the tone controls are based around 1kHz.
Is the 2kHz dip intentional? Is it a BBC dip? The midrange is cut quite steeply while the tweeter is crossed a bit higher. This could be intentional to introduce that dip. However, this seems a bit too steep for the standard BBC dip. That is what makes me think it might not be intentional. I don't know for sure, though.
In my humble opinion, I think a couple well-implemented parametric EQ bands would take this from a “great” speaker to a “benchmark” level speaker. If you are on the fence about this speaker, I think it’s definitely worth consideration. Buy it from a reputable dealer with a liberal return policy and give it a shot.
Support / Contribute
If you like what you see here and want to help me keep it going, please consider donating via the Contribute link located below. Donations help me pay for new items to test, hardware, miscellaneous items and costs of the site’s server space and bandwidth. All of which I otherwise pay out of pocket. So, if you can help chip in a few bucks, know that it is very much appreciated.
https://www.erinsaudiocorner.com/contribute/
Haint
Was the BBC dip introduced intentionally, or is it an unavoidable artifact of the dual woofers and tweeter arrangement?
hardisj
hardisj
Reviewer
North Alabama
I wondered the same. The midrange is cut quite steeply while the tweeter is crossed a bit higher. This could be intentional to introduce that dip.
richard12511
I'm guessing it's a sacrifice they had to make in order to get the extra spl they wanted from the 2.5 way.
The 5-8/9kHz dispersion widening though is (imo) intentional. I see it in all the Focal speaker measurements.
MZKM
Land O’ Lakes, FL
Note: Rating is for far-field listening
Preference Rating
SCORE: 3.8
SCORE w/ sub: 5.7
Frequency response: +/-5dB 40Hz-20kHz ; +/-2.8dB 80Hz-20kHz
_________
Switching it to vertical orientation actually is worse at 3.7, the w/sub is the same at 5.7 though. However, the listening window is much closer to the on-axis, and since my assumption is that the listening window becomes more important in the near-field, the performance may actually sound better despite the larger dip in the ER & PIR curves.
napilopez
NYC
Thanks Erin! I have to say I don't totally understand this driver layout for a studio monitor and directivity doesn't look great but it's interesting for sure.
That said, the wide dispersion between 3-9khz is imo what gives focal its 'house' sound and I find I really like that. But I'd probably prefer to opt for a more 'normal' design.
As it so happens I currently have the Solo6 Be for testing so I'm curious to see how it holds up.
Edit: I doubt the BBC dip is intentional too. Not something I've really seen with other Focal speakers.
Pearljam5000
What are your impressions of the Solo6? Thanks
Mnyb
Sweden, Västerås
Very good review ! Great that you specifically investigate appropriate listening distances for the DUT .
Pro speakers usually have a recommended application in mind "nearfield" or " farfield" then a recommended distance .
Hifi speakers don't come with that but it's obvious that the same physical laws apply so even a hifi speaker have a "target application" otherwise they would not be able to design the thing. But Hifi speakers manuals are very vague about that , suppose marketing is involved if you are specific you exclude some potential customer ( use our 5" two way in your cathedral sized room ) .
pierre
Switzerland
Thanks Erin for the review. I had this speakers for years and I liked them. It may be expectations bias but when I bought the Focal Trio6 to replace them, I thought they were significantly better.
I generated 2 EQs for this speaker: one that only optimise the valleys and one that does both valleys and peaks on the freq graphs.
1. Only allow negative corrections:
Score goes from 3.8 to 4.6
The first to PEQ are the most efficient:
Code:
EQ for Focal Twin6 Be computed from ASR data
Preference Score 3.8 with EQ 4.6
Generated from http://github.com/pierreaubert/spinorama/generate_peqs.py v0.7
Dated: 2021-04-08-07:50:43
Preamp: -0.2 dB
Filter  1: ON PK Fc 10678 Hz Gain -1.87 dB Q 1.60
Filter  2: ON PK Fc  4929 Hz Gain -1.22 dB Q 2.71
Filter  3: ON PK Fc  6547 Hz Gain -0.97 dB Q 12.00
Filter  4: ON PK Fc   583 Hz Gain -0.43 dB Q 12.00
Filter  5: ON PK Fc 10055 Hz Gain -0.40 dB Q 12.00
Filter  6: ON PK Fc  1370 Hz Gain -0.73 dB Q 12.00
Filter  7: ON PK Fc  1583 Hz Gain -0.69 dB Q 12.00
Filter  8: ON PK Fc  3715 Hz Gain -0.69 dB Q 9.91
Filter  9: ON PK Fc  4061 Hz Gain -0.48 dB Q 12.00
Filter 10: ON PK Fc  3352 Hz Gain -0.46 dB Q 12.00
Filter 11: ON PK Fc  5708 Hz Gain -0.31 dB Q 12.00
Filter 12: ON PK Fc   300 Hz Gain -0.42 dB Q 12.00
Filter 13: ON PK Fc 10039 Hz Gain -0.20 dB Q 12.00
Filter 14: ON PK Fc   344 Hz Gain -0.40 dB Q 12.00
Filter 15: ON PK Fc  1303 Hz Gain -0.29 dB Q 12.00
Filter 16: ON PK Fc  1592 Hz Gain -0.28 dB Q 12.00
Filter 17: ON PK Fc  4061 Hz Gain -0.23 dB Q 12.00
Filter 18: ON PK Fc  3284 Hz Gain -0.22 dB Q 12.00
Filter 19: ON PK Fc  6198 Hz Gain -0.20 dB Q 12.00
Filter 20: ON PK Fc   586 Hz Gain -0.22 dB Q 12.00
2. EQ which optimise for both peaks and valleys:
Score goes from 3.8 to 6.1.
I forced the LW to go down to -3 dB (it marginally improved the score). First 8 EQs are useful.
Code:
Preference Score 3.8 with EQ 6.1
Dated: 2021-04-08-07:57:36
Preamp: -2.6 dB
Filter  1: ON PK Fc 10055 Hz Gain -3.30 dB Q 0.44
Filter  2: ON PK Fc  2079 Hz Gain +3.25 dB Q 5.52
Filter  3: ON PK Fc  8165 Hz Gain +2.09 dB Q 6.95
Filter  4: ON PK Fc  4023 Hz Gain -1.13 dB Q 2.21
Filter  5: ON PK Fc   584 Hz Gain -0.88 dB Q 12.00
Filter  6: ON PK Fc  1583 Hz Gain -1.77 dB Q 8.83
Filter  7: ON PK Fc 10112 Hz Gain -1.08 dB Q 11.51
Filter  8: ON PK Fc  2508 Hz Gain +1.04 dB Q 6.72
Filter  9: ON PK Fc  1851 Hz Gain +1.11 dB Q 12.00
Filter 10: ON PK Fc  6521 Hz Gain -0.38 dB Q 12.00
Filter 11: ON PK Fc  1324 Hz Gain -0.85 dB Q 5.61
Filter 12: ON PK Fc   463 Hz Gain +1.02 dB Q 12.00
Filter 13: ON PK Fc   647 Hz Gain +0.64 dB Q 12.00
Filter 14: ON PK Fc  7424 Hz Gain +0.78 dB Q 12.00
Filter 15: ON PK Fc  8835 Hz Gain +0.53 dB Q 12.00
Filter 16: ON PK Fc  1126 Hz Gain -0.50 dB Q 12.00
Filter 17: ON PK Fc   391 Hz Gain +0.65 dB Q 12.00
Filter 18: ON PK Fc  5589 Hz Gain -0.34 dB Q 12.00
Filter 19: ON PK Fc  3269 Hz Gain -0.58 dB Q 12.00
Filter 20: ON PK Fc  2102 Hz Gain -0.51 dB Q 12.00
dfuller
This is about what I expected of the Twins. The 2.5 way kinda thing is just kinda... not great. Lots of interference between the mid and tweeter in that crossover region. I've heard a lot of people mounting these vertically so they're at tweeter axis, which seems to do better?
But yes I would like to see the Trio6 or Trio11.
The distortion performance is excellent as I expected - low distortion is absolutely Focal's strong point.
thewas
dfuller
Detailed measurements of the Trio 11 by Sound & Recording can be viewed here
https://www.soundandrecording.de/equipment/focal-trio11-be-−-midfield-monitor-im-test/
It can be seen there that Focal cleverly adjusted the on-axis response to compensate the directivity problems leading to a nicely smooth in room response which doesn't really need EQ above 500 Hz:
Damn! The Trio11s may just be the move after the FP01s... That's real goddamn impressive.
hardisj
hardisj
Reviewer
North Alabama
I have updated my reviews with a linearity metric and a statement regarding sensitivity/linearity to help people more easily see. I was doing this before but forgot to include this in my latest reviews.
Response linearity is -2.81/+2.81 dB from 80Hz to 16kHz.
dfuller
Huh. Not too bad on-axis. Too bad the in-room response is so weird.
LTig
Europe
I really want to like Focal, but this is just a mess.
Yep. Any parameter or measurement is easily beaten by the KH310. And this with a smaller housing and a real 3-way, all for the same amount of money (AFAIK).
