Frequency Response Test Records
morillon
Balle Clorin
You mean this ?
morillon
yes
not for classic methode etc but for the equation...often an obscure subject..
and sorry.. the most original is about mechanical impedance mesureament...
the book, box, is probably the most rich technicly ...(with the str-14 in a completely different genre..) , lots of things to learn there...
Balle Clorin
View attachment 320341New arrival. Denon XL-7004/7005/7006.According to some sources XL-7004=XG-7001
Looks interesting with 30 page booklet , maybe I can run some sweeps tomorrow.
Sweep has low turnover frequency of 250hz acccpring to Google translate
Booklet shows a plot of skating force across record that I have not seen before..
Fequency sweep, line in no EQ
Puffing EQ 250R-0 did not flatten it quite, here compared with Clearaudio TRS-1007
Andysu
got cheap fish and chips vinyl check technics sl-1210gr
Balle Clorin
By accident I bought a mint Denon XG-7001 from Discogs. I did not realise it is the same as XL-7004 I have, well well.
Balle Clorin
I compared denonXL-7004 and XG-7001 which are the same record but two different issues..XL-7004 gave nicer high frequency matching, Crosstalk better than 30db on both.
Nice cart-arm low resonance test. Here AT33PTG/II ON SME v
XG-7001 Crosstalk, HP filter 250hz
morillon
there is another rather special version "hq-180gr"..it is the reissue of rti at the end of the 90s for the "japan audio society"
Balle Clorin
Yes I saw that one too, not sure I will spend money on that too, my XL-7004 to 7006 triple album and XG-7001 are both NEW IN BOX/Mint quality
Balle Clorin
AT-33PTGII left channel Denon XL-7004 vs B&Q 2010. Only relevant to compare 1000hz+
JP
Brookfield, CT
onekftstart = 1
MaxwellsEq
what’s test audio files?
Hi, welcome to ASR. Your question is a bit off topic (this, thread is about test LPs). I recommend you search to find threads discussing audio test files. Simply put, an audio test file is a file such as a WAV or FLAC file with test tones and sweeps instead of music.
mfalcon
What’s the best test record (frequency sweep) that is easy to purchase in the US? The CBS and Denon that are favored aren’t easy to source.
JP
Brookfield, CT
STR-100 is going to be the easiest to find.
narud
is there a source for the clearaudio record where shipping to the us isnt almost as much as the record itself?
mfalcon
How many uses are people getting out of the STR-100. Is it a myth that they only have so many spins?
