oliviabrandon361
- Joined
- Jan 6, 2024
- Messages
- 2
- Likes
- 1
gre
GREAT ANALYSIS....How Our Results Compare to Official Laboratory and Professional Review Measurements
Click on images to increase size
Sony XL-30
View attachment 321412View attachment 326776
When possible, my posts will include official measurements for comparison. Here I am providing a single channel measurement to make the introduction easier to understand. You can see that the 2nd and 3rd harmonic distortion results set our measurements apart from most others (the distortion axis is on the right). Note that the B&K QR 2009 and Victor (JVC) TRS-1005 Sony used both show a frequency response dip between 2-10kHz when compared to the more accurate JVC TRS-1007 and CA TRS-1007. For our purposes, assuming correction, these results match almost perfectly. Not bad considering the 45+ years separating the measurements!
Audio-Technica VM540ML
View attachment 296359View attachment 321415
The first measurements are from Low Beats and were taken with JVC TRS-1007. The second are from Home Theater Hi-Fi using CBS STR-100. Note that measurements from the latter are generally not reliable. The reasons become clear when you consider every other example.
View attachment 326775View attachment 326774
The first is a single channel measurement made by @Digital1955 for an early version of the script. I adjusted the frequency response to match CA TRS-1007. There is no crosstalk information available with a mono recording.
The second was made by @mackat. Again, FR was adjusted to match CA TRS-1007. Total capacitance is unknown but likely high. The limitations of the CBS STR-100 test record remain with respect to the other variables and can be seen clearly in the crosstalk results, which are here limited to around -20 dB at 1kHz (use phantom center point).
View attachment 297712View attachment 326772
And here are two more recent measurements. The first is from @dougi. The final one is my own measurement. Note the graph style is slightly different from the two above, with the distortion axis located on the right side.
This might be the most measured cartridge out there! All things considered (including the different loading settings and phono stages), the results are very consistent. So much for turntables having a unique sound signature of their own. Readers can have confidence in the measurements, compare the frequency response to that of other cartridges, determine best or preferred loading settings, and even figure out if a cartridge is incompatible with their set-up (e.g. total capacitance afforded by phono stage does not produce optimal results).
