- Joined
- Jun 19, 2018
- Messages
- 6,652
- Likes
- 9,407
There are some, Lyngdorf 3400 for instance ... I'm running a Technics SU-G700 right now, it's also an FDA (Full Digital Amplifier)
I'm not sure actually. That Technics says it uses a PCM1804 chip, which is a DA converter. That would imply that DA conversion occurs prior to the amp stage.
And I'm not sure about the Lyngdorf either, the specs list RCA outputs which also suggest that DA conversion occurs before the amp stage.
Do you have any further info on these which shows that they are direct digital amps?
