FX Audio DAC-SQ3 Review
This is a review and detailed measurements of the FX Audio DAC-SQ3. It was sent to me by the company and sells from US $86 to $100 (latter on Amazon with Prime shipping).
The DAC-SQ3 is USB powered and comes with a remote control which is unusual in this price bracket:
I like the large display and choice of green for data format. You can adjust the volume control using the two buttons or the aforementioned remote control.
DAC-SQ3 can also act as a digital bridge, converting USB to COX and S/PDIF:
FX Audio DAC-SQ3 Measurements
The default output is about 2.3 volt so I dialed it down a notch to get to our nominal 2 volt output:
Hey, this is pretty good! Distortion is extremely low (below threshold of hearing) and adding noise to it, we are still in competent category:
Dynamic range is good:
Overall performance though can't keep up with more expensive products:
Then again linearity is pretty good:
Only one filter is provided which is a decent one:
But doesn't attenuate enough so causes THD+N vs frequency to have worse than average noise:
Multitone test again shows off its low distortion:
Nice to see performance is maintained here while providing above average feature set as far as remote and volume control. You pay less and get a bit less performance.
I am going to recommend the FX Audio DAC-SQ3. It carves its own niche as far as features+performance.
GimeDsp
Earth
That "volume" instructions on the right side though. I can tolerate the green display sections but I can't let let that slide.
Rja4000
Liège, Belgium
Hi @amirm
thanks for the review.
We were discussing a few days ago:
How many harmonics do you allow in THD vs Frequency ?
It's a setting on AP, isn't it ?
Rja4000
Liège, Belgium
It is variable and limited by bandwidth of 90 Khz .
So it's limited by bandwidth only, you don't limit it to, say, 5 or 9 harmonics ?
REW, as an example, limits to 9, in frequency sweep, if I'm not wrong.
Tangband
Sweden
This is almost at Topping D10s measurement-level plus a remote control with volume regulation to ! Very nice.:)
Combining with Apple Music high resolution , camera connection kit and you have a nice streamer with volume regulation and digital outputs.
Is the digital outputs from the device also volume controlled ?
ceausuc
Nice one. It almost makes topping d10 look expensive :)
It's time for small cinese builders like FxAudio to get their hands on one of these APxxx analyzers :)
When that will happen it will be just a matter of time before they will deliver good measuring dacs at low prices and SMSL/Topping will start having some competition.
MCH
Hello, does anybody know if a pi could power one of these OR if one of those Y usb cables (power/data) would work?
If yes, this could be the "ultimate hat", for just a little bit more than a regular audio hat....
Vini darko
Dorset England
Thanks for the review Amir.
How many volume steps does it have?
Is the digital output a clean conversion?
Reactions: Tks
sseppala
Thank you for the review. Progress has been fast, just to think, the performance is a bit above my Benchmark DAC1 and a bit lower than the DAC3.
I would really appreciate if Amir could make the SINAD / Measured Level graph standard on all DAC reviews and perhaps extend the range to 100mV to max (about -26dB) . I think it would be especially interesting to compare these remote control models in this regard. Seeing these measurements would really ease my digital volume control anxiety.
EDIT: Just realized, that maybe this would not be completely reflective of the devices volume control, as obviously in this measurement the signal output level is controlled by the input signal of the dac. Though, in most cases they are probably the same. Perhaps a single 50mV SINAD would be better, like in the headphone AMP measurements.
audio_tony
Leeds, UK
It's USB 2 and hence if it conforms to the USB standards, the Pi will power it with no problems.
The Pi powers my Topping D10 without any issues.
Reactions: MCH
PeteL
I Wish i would have Toslink/SPdif inputs and not outputs.
You have the choice of literally hundreds of models of DACs that offer Toslink and SPDIF inputs, this one is different. This one is for someone who may need a USB to SPDIF bridge, I don't see why you would feel that you need an other DAC that does the same as everyone else?
Why? its just software volume control?! adjust at the source not at the converter.
Maybe because your source may not have a remote control?
Tangband
Sweden
Amirm - It would be really interesting if you could measure the digital output on the device with the volume set to:
1.= 0 db ( max )
2.= -30 dB
Is there any sampling rate conversion going on , is there higher distortion when the volume is lowered ?
Many people in this thread are asking for the same measurements.
It would be really nice.:)
