- Joined
- Sep 16, 2019
- Messages
- 1,201
- Likes
- 2,652
Today I performed measurements of the Genelec 1032A speaker. This is a model dating back to 1992, and it is the largest 2-way model made by Genelec. It is also the model I'm using as LCR in my small home theater room. The most recent version is the 1032C so in a way, despite it being a 28 year old design, it is still a current model in a basic sense.
The measurements were performed in a large space at 2m distance using the ground plane method which yields good accuracy using a 15ms gated window. Ended up making a platform and putting the speaker 6ft up in the air in a room with a height of 13ft. Special thanks to members Hardisj and Napilopez for tech support.
Measurements were performed using the acoustic axis as stated in the manual, which is at 29cm from the bottom up and roughly inbetween the woofer and tweeter, and was aimed directly at the microphone capsule.
Since I don't have the software needed to properly weight the measurements to present a proper spinorama, I was hoping this post is being read by someone who can (and perhaps even splice in the bass from the nearfield measurement) while I try to figure it out myself. Thank you Napilopez for the thorough explanation.
Spinorama courtesy of @napilopez
0-90°H
Vertical up
Vertical down
Polars
Grille effect on-axis
Nearfield
Listening window consistency. The slight 'outlier' is 10° below the acoustical axis.
0-90°H
Vertical up
Vertical down
Polars
Nearfield
