Genelec 8010A Powered Studio Monitor Review
This is a review and detailed measurements of the Genelec 8010A Powered Studio Monitor (speaker). It was kindly purchased by a member and drop shipped to me for testing. It costs US $350 each for $700 for a pair.
I don't know that the scale comes across in this picture but the 8010A is tiny:
The 3 inch woofer enables it to be small. Being made out of the same aluminum material of its larger brothers, it is every bit as study and tough.
The figure 8 power cable and XLR get inserted vertically so you need to make sure the latter does not have too long of a strain relief or it may hit your desk:
Genelec 8010A Studio Monitor Powered Speaker 2-way stereo review mastering back connectors swi...jpg
I performed both measurements and listening tests with all switches in their default position as you see.
I used over 1000 measurement which resulted in error rate of slightly above 1% in the lower treble frequencies.
Temperature was 68 degrees. Measurement location is at sea level so you compute the pressure.
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
The reference axis was as instructed in the manual: the top of the woofer. I also tested it with tweeter axis and it made no difference.
Note that with powered monitors, the computed SPL is not correct with Klippel NFS. I manually compensate for that it is not exact.
Spinorama Audio Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
Genelec 8010A Studio Monitor Powered Speaker Spinorama CEA2034 Frequency Response Measurements.png
We don't have ruler flat on-axis response but the variations sans the 1 kHz are small. There is a bit of of bass boost though.
Back to 1 kHz, we can see the port producing undesirable response around that region:
Early window reflections are near perfect which means this speaker will be very room friendly and not picky about placement:
Genelec 8010A Studio Monitor Powered Speaker Spinorama CEA2034 Early Window Frequency Response...png
Summing all of this together, we seen a speaker with very nice response albeit, with a bit of bass boost:
Genelec 8010A Studio Monitor Powered Speaker Spinorama CEA2034 Predicted In-room  Frequency Re...png
The amplifiers for the woofer and tweeter are just 25 watts. I suspect the amp is clipping before the woofer is:
Genelec 8010A Studio Monitor Powered Speaker Relative THD Distortion Measurements.png
Genelec 8010A Studio Monitor Powered Speaker THD Distortion Measurements.png
I don't have the heart to show you the 96 dB SPL response. :)
Directivity is good:
Genelec 8010A Studio Monitor Powered Speaker Horizontal Beamwidth Measurements.png
Genelec 8010A Studio Monitor Powered Speaker Horizontal Directivity Measurements.png
The small woofer naturally has wide beamwidth at lower frequencies than a larger woofer would.
Vertical response also benefits from smaller woofer:
Genelec 8010A Studio Monitor Powered Speaker Vertical Directivity Measurements.png
You have much more leeway as far as vertical placement although it is still advised to have the tweeter pointed at you.
Genelec 8010A Speaker Listening Test
I placed the 8010A on the left side of my monitor on my 5 inch high stand as I always do. First impression was superb: this thing has incredibly tonality with a warm sound that belies its small size. I know it is a cliché and I hate the term it is absolutely unbelievable how much bass comes out of this speaker. In comparison, it made my Neumann KH80 DSP sound dull. Track after track in my play list sounded superb. Excellent tonality, detail and dynamics. This is no flat sounding studio monitor.
There is however a major flaw: hit anything with deep bass and the 8010A will complain with the worst crackle you can imagine. It goes from amazing to wow, this thing just broke! Strangely, I could not filter out the lows enough to get rid of this effect while preserving that gorgeous amount of bass.
If you are using the 8010A for pro work (mixing) you should be aware of its warmer tilt and perhaps correct for that.
If you want to get a taste of what I call sonic perfection in a small package, get the Genelec 8010A. Don't play it too loud or too deep and you will be presented with delightful sound that simply does not come in a package this small. Yes, $700 is a lot of money for small speakers but if you enjoy music as much as I do while working, you owe it to yourself to at least try these out.
My only wish -- and one that remains with all Genelec speakers -- is to have a dynamic compressor for bass. JBL has this to good effect. A speaker shouldn't go from hero to zero like these speakers do when they run out of power. Then again maybe this is a motivation to buy the much larger Genelecs to be free of this restriction!
Needless to say, it is my pleasure to my the Genelec 8010A on my recommended list.
Have to go and help my wife cut and freeze the last of our nice pepper harvest this year:
Planted the smaller and oddly shaped ones this year that you see mixed with the larger ones (forget the name). Was surprised how much tastier they were than the normal "California Wonder" that everyone plants.
There may be another shortage of seed next year so need to stock up now. So an infusion of cash from you all in the form of donations would be nice: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
  • Genelec 8010A Spinorama.zip
Ron Texas
Thank you @amirm for another detailed set of measurements. Genelec really has it together. Unfortunately, the larger speakers capable high volumes at midfield distances are expensive. Perhaps $700 isn't so bad for a desktop setup these days. Glad to see you have a bumper crop. My son grows a lot of stuff in his tiny yard in the Bay Area. Their toddler daughter snacks right out of the garden on real food instead of fruit loops from a box.
JohnYang1997
China
Well, it has two 3.5" woofers instead of a single 3" and costs 90€ more (here). The 8020D is the actual competitor (same price, same advertised amp power and more comparable woofer area).
Well. Price can vary across countries. They are exactly the same price in China tho.(mtm and 8010) (in US as well.)
EchoChamber
Thank you for the review @amirm !
I have to say that since going all Genelec recently (ASR was a big influencer), my 2 speaker systems have been transformed. I do feel they come with more bass than is typically needed for more flexibility in placement. Once I set the bass tilt to -4dB on my 8030C’s they became much better balanced in my attic room in a midfield setup placed close to the wall.
Linus
Any idea as why Genelec are so expansive in the US?! We can get them much cheaper in Canada.
EchoChamber
My guess is too much overhead with marketing and support (or because they can and the US pro market will pay for it)... I bought my 2 pairs and accessories from a French pro audio online store. Without VAT, it was a good deal, shipping costs were very reasonable, and I didn’t have to pay any US custom fees (but I was ready for it).
GD Fan
NY, NY USA
Forgive what might be a stupid question, but if the port is causing a small issue would it be beneficial to plug the ports? The ports on my floorstanders are plugged, but the Genelec 8320s on my desk may be another story.
waynel
Please remember that this is intended as a professional monitor for the music creation process. If it used a compressor on the bass when playing loud, music could be mixed with too much bass. Better to crackle or even turn off to let you know the monitor is unsuitable for the purpose and to get a bigger model.
richard12511
The issue is very small compared to huge contribution it makes to bass:
The main driver starts to droop at 140 Hz already. The port shifts that to below 80 Hz.
milezone
Seattle
There's a pair of these listed on ebay right now for $400........
They sound great however I find them to be a bit anemic compared to the slightly larger Genelec monitors. The 5" driver in my 1029s is the sweet spot in my experience.
We had a "large" yard in Bay Area by their standards (one third of an acre) when we lived there but could not grow a lot. I actually converted our front yard when we lived there to vegetable garden! Our dirt there was also hard clay and there were a lot of issues with bugs and disease. Here we don't have the sunshine but boy, is the garden disease and pest free. And of course land is very available. We probably have an acre dedicated to this garden. This year we planted by far more than any other year.
