Genelec 8050B Review (Studio Monitor)
Sancus
I don't see much benefit. We have the spinorama for 8341A and SPL/distortion for 8361A.
It's about completionism, sir! Plus I think there's a high chance it would take the score record. But yeah I agree it's not a huge priority or anything, I just think it would be a fun review and finding out the woofer's performance at 96dB would be somewhat useful.
Thomas_A
Sweden
Subjectively, what effect would you say this has. The 8030c I own has the same dip, and it shows in all of my MM measurements, and @Maiky76 s EQ tweak fixes it. I also have the M105 on hand to compare and see if I can notice the difference.
It reduces the timbral effects of comb filtering, i.e. the stereo system errors. Objectively and subjectively there is an exaggeration of the 2-4 kHz region vs the 1-2 kHz region when speakers are used in stereo vs mono.
daftcombo
This is what you have in mind, I think.
Thomas_A
Sweden
Yes. Even in normally reflected room there is a timbral shift between a single mono speaker and a mono source played in a stereo setup. A speaker that has a dip in the 1-2 kHz region followed by peaking 2-4 kHz will just exaggerate the effect. I prefer the opposite. This is not a solution to the problem but compromises due to the flaws of the stereo system.
daftcombo
Aren't stereo recordings mastered & monitored in stereo though? So the problem would be there only with mono recordings, and you can use only one speaker in these cases.
Thomas_A
Sweden
You can argue both ways. Evaluations of speaker performance has been done mostly with a single mono speaker just because it is the most sensitive method. All current evidence points that a perfecly linear on-axis response is preferrred. Putting the same perfecly linear speakers in a stereo setup will lead to a timbral change. So what then is the perfect stereo speaker? It cannot be both.
The solution is a centre speaker to replace the center phamtom image. In the opposite case, should the center speaker deviate from the left and right ones? So for those who use without a center speaker, I would say it is a matter of choice. I prefer a slight deviation from linear. Speaker with lower energy 1-2 kHz vs 2-5 kHz tend to sound a bit bright and somewhat unpleasant.
daftcombo
Which speakers corresponding to those cases did you audition?
Also, can't you EQ a stereo system made of flat speakers based on the graph (e) I posted upper and see if you prefer it that way?
Thomas_A
Sweden
I have been testing this for more than 15 years in my DIY design so I have settled for a slight compensation Note that any compensation is in the range of maximum +/- 1,5 dB or so. Not more.
Thomas_A
Sweden
Personally I think it would be more interesting to hear what others think about this, in a subjective listening test, than just me. I.e. EQ of speakers, in stereo setup +/- 30°, that mimic the on-axis response as measured by Shirley et al vs the inverted response of that, within +/- 1,5 dB. In a second test one could test the inverted response vs a linear response.
daftcombo
This is a very good idea. If some of the EqualizerAPO pros out here can do a little file, otherwise one can do one in RePhase.
Thomas_A
Sweden
With respect to 8050B vs the Revel 106, one could imagine that there is a slight compensation built on of the Revel. Whether it is on purpose or no - I would not make any guess of that.
daftcombo
Something like this in Rephase.
Everybody can try with his/her speakers at home!
Thomas_A
Sweden
One note is however that the position of the dips/peaks depends on the angle of speakers, and also that the above EQ is based on the speakers being totally flat on-axis. So one need to adjust accordingly. In addition there are some other factors to consider in the "fill-in" of the dip peaking at 1,8 kHz for 30° angles. It will mainly be filled in using reflections. Heavy toe-in may or may not be a solution, depending on the speaker design.
Takanaka
I don't think the 8050b has a DSP performing digital crossover. AFAIK it has an analog crossover.
I wonder about the dip between 1.5 and 2 kHz and the deep bass trouble.
I think investing some $400 more for a KH310a gives you a better speaker without the (relatively minor) flaws of the 8050b. In the EU the price difference is only €200 so choosing the Neumann seems to be a no brainer.
Little off-topic but where did you see the 8050b and KH310A with a price difference of €200? I looked them up at Thomann and the 8050b is €1399 a piece and the KH310 €1699 which is a €600 difference for a pair.
daftcombo
I've tried the EQ I made with Rephase on my Aria 906, which are placed with me forming an equilateral triangle. It is pretty good!
Thomas_A
Sweden
Ok Just a note from me though. The Focal Aria 906 frequency response seems already to have some deviations that are similar to a correction, according to Amirs measurements. It can be too much if you add upon what the speaker already has. What would be interesting is if you would do a correction so that the response is opposite of the speakers output. It would mean decreasing the response by 2 dB at 1-2 kHz and boosting by 4-5 dB at 3-4 kHz and 7-8 kHz. Listen to soprano voices.
daftcombo
It is difficult because Aria 906 directivity is not perfect. I can try it of course.
LTig
Europe
I also looked at Thomann and then the price difference was €200 per speaker.
