Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 5,292
- Likes
- 5,546
I do wonder how the 1237A compares to the 8361A, Specs are similar but design is obviously different
https://www.genelec.com/correct-monitors
Mainly loudness and direct sound dominating (if that is what you want, I do).
The bigger models are more suitable for longer listening distances IMO, subwoofer or not.
Do the larger models have narrower dispersion?
@andreasmaaan
Thanks
It's just that it's pretty confusing because the 8361A, 1237A and the new S360 have pretty similar specs and cost exactly the same in my country so it's hard to decide lol, but I think I like the 8361A the most because of the coaxial design.
Now add the Kii Three and D&D 8C to the mix and its almost impossible to choose lol.
Kii Three, dunno if one wants a cabinet full of potentially breaking Hypex modules?
Do Hypex modules break more frequently than other amplifier modules?
I presume so.Do the larger models have narrower dispersion?
Considering there's so many inside, I guess the chances of breaking is higher. Personally I would discard the speaker on bass SPL anyway.
Do you have a link to data concerning the Kii's bass SPL capacity by any chance?
Thanks. Obviously not great, but better than most models in the Genelec One series, unless I'm missing something?
E.g. significantly better than 8351A:
Why do you keep posting the deprecated 8351A graphs (sorry if it wasn't you, but keep constantly seeing it)?
Also the 8351A is the older discontinued model that was worse even than the 8341A, the updates model 8351B is much better.
Does either of you have links to similar measurements of either the current 8351 or current 8341? Of all the measurements I can find online, the 8361 seems to be the only one with reasonably high max. SPL in the bass.
