- Joined
- Aug 14, 2018
- Messages
- 2,778
- Likes
- 8,164
I was listening at about 2,5 meters.
It was in a room of about 5 meters wide and about 8 deep.
I was listening at about 1/3 volume to half volume at maximum. There was a dac/pre in between when listening at that volume. When connected digitally I had it at about 25% volume. 40 to 50 would be movie type loud, seriously loud. I haven't heard the 8361 but when listening I was wondering why anyone would need a a bigger loudspeaker or even a sub. (You could probably use a sub if you wanted the utmost and use it for movie watching. All imo of course, with the caveat that I haven't heard it with a sub or the 8361).
Summarising: I think it's plenty loud, but to make sure you could take a look at what Genelec advises for your room size and desired spl.
Another thing that I would personally consider is the size of the monitor, where imo the 8351 is a nice volume, not too big. For myself I would buy the 8351... and a sub if I ever felt the need or flush with money to spend.
Edit: reading Amir's review and measurements of the 8351 and 8361, I probably listen at a lower volume than 85db when listening to music. He either has a really big listening space, or tries to test the monitor to the max, which translates to me as:
-are you searching for the best sound money can buy? Buy the 8361. Spending more would be silly.
Are you like me and listening to music lower than 85db? Then probably the 8351 would be just as good. Only when using in a big space and or with lots of high volume bass heavy music or playing movies, then imo the 8361 or a sub would be necessary. It could also be that I missed the overdriving of the bass units, but if that was the case, then imo you really need trained ears to hear it at the volume I played.
Thanks very much - this is really helpful! My room is about 5M wide as well, but about 6.5M deep. Like you, I don't listen super-loud, and I also do not feel the need for a sub to the degree that many others do (or I guess that I should? ). I love solid, tight, low-distortion bass, but a speaker's frequency extension below about 35Hz has never been a make-or-break for me.
