Going active (using Hypex plate amp FA253)
Holmz
Australia
There are a few posts on the topic… However I’ll ask it again for a specific amplifier/DSP and a generic speaker.
What is the preferred method for going active with some existing speaker(s), for example a generic/theorhetical 3-way?
My thoughts are:
  • Use a Hypex Plate amp like the FA253
    • https://www.hypex.nl/product/fusionamp-fa253/157
      • Which is 250w/250w and 100w for the Woofer/midrange/tweeter respectively.
    • Select cross over points and slopes and implement them in the Hypex
    • Use REW for frequency smoothing, as there are 15 bi-quads per Hypex Core.
  • If one was to hook this up to something like a Lyngdorf with room correction, then would/should I get the system flattened in Hypex? Or just use the Lyngdorf?
    • Skipping the leveling in the Hypex?
    • Or level in the Hypex, and also do any ALLPASS or phase correction work in the Hypex
    • My impression is that Lyngdorf’s Room Perfect does frequency leveling with IIRs, And not a FIR based approach like Dirac (DRC).
Thoughts are appreciated.
jhaider
Unfortunately, the preferred method is:
  • Take them outside on a windless day (assuming you don't have access to an anechoic chamber or Klippel NFS).
  • Take measurements of each drive units in the cabinet, at least 180deg horizontal in 5-10deg intervals, and ±30deg vertical in the same intervals
  • Depending on the size/complexity of the bass alignment, you will want to supplement with nearfield measurements or ground plane measurements and work out the splice
  • Import your measurements into a simulator (VituixCAD is very good; Boxsim is another I've heard good things about but have never used)
  • Design your filters
  • Import your filters
  • Listen
  • Repeat the last three steps until you're happy or you give up
