Good amplifiers for acoustics laboratory
pedro.carvalho
Hello folks, I've been researching this topic for quite a while and, before I invest in anything, I would like some opinions.
I am working on a small acoustics laboratory, to measure the resonant frequency of materials, few techniques of active noise canceling, and so on.
Given those circumstances, I need an amplifier with independent mono channels and low noise (in the sense that the mechanical part will not produce noise). Therefore, I thought that class D can be a nice way to go.
Keeping in mind the previous specifications (class D is not a hard one), do you have any suggestions for an amplifier that might fit the labs?
M00ndancer
Sweden
Budget?
Noise floor required?
Trouble Maker
Columbus, Ohio, US
I worked adjacent to our NVH team and with them at times, used (not setup or post analysis) the NVH test/data acq. equipment, so I have some exposure but not expertise.
There a many industry standard equipment and test methods, though the equipment and software are usually expensive. Curious about what you are trying to do that these systems can't?
https://www.plm.automation.siemens.com/global/en/products/simulation-test/acoustic-testing.html
https://www.google.com/search?q=impact+hammer+vibration+testing&tbm=vid
Edit: Or maybe you are using these for the test an analysis and the amp is just for noise cancellation application?
P
pedro.carvalho
Budget?
Thank you for your reply. I am sorry, I thought about the price but I forgot to add it to the post. I am willing to spend up to $1000 on this amplifier.
Since I am normally dealing with quite loud signals, noise-floor is not something I am worried about. Anything over 100dB SNR will please me.
P
pedro.carvalho
We are already conducting measurements with an SVANTEK 979, it fits our low-budget startup-like company. We are normally writing our own software to retrieve the results from the tests.
The amplifier will be just to drive the speakers with the sound source - both for as noise source for testing, or part of the setup for noise canceling. :)
M00ndancer
Sweden
Brand and model of the speakers?
Specifications?
Speedskater
Cleveland, Ohio USA
I would look into pro audio amplifiers. They have a more robust construction, they are designed to be moved from place to place and be used with different loudspeaker loads.
