Did you install the Gustard driver for Windows?
Yes but for some reason, the output devices (on win11) do not use the custom drivers. The output USB device uses the Microsoft one.Did you install the Gustard driver for Windows?
There was an updated driver a few months ago......check the Gustard websiteYes but for some reason, the output devices (on win11) do not use the custom drivers. The output USB device uses the Microsoft one.
It just amazes me people having problems with Windows and Gustard X16 playing DSD or X16 showing 48khz. I suppose I'm lucky not to encounter such issues and never have to upgrade fw. My playing sources are DAPs...sony nw-a45/55/105, Hiby R5, Shanling M0, Fiio M6. So far I have no problems plugging these DAPs to X16 via USB.
Anybody know if there are discreet remote codes for the various inputs or do I have to step through them?
The display fonts are so small, I have to go right up to it.
Hi all - Just acquired a Monoprice Monolith THX AAA Balanced Headphone Amplifier featuring THX AAA 887 Technology. Thinking hard about how to set it up with my X16. So much so I've raised a few questions here: -
https://www.audiosciencereview.com/...nolith-thx-aaa-887-headphone-amp.31366/page-3 (post #41). Not getting much by way of any response so I thought I'd copy over given I will be connecting to my Gustard. Hoping some kind folk will be able to answer. Thanks in anticipation
Your questions where answered in the very next post on that thread. If you dont have balanced head phones there's no point converting the plugs to balanced if the DAC has a single ended option, 1/4" or 3.5. You can use adaptors if they are made correctly but as post No 42 said, there's nothing to gain, your halving the signal output power in the conversion.Hi all - Just acquired a Monoprice Monolith THX AAA Balanced Headphone Amplifier featuring THX AAA 887 Technology. Thinking hard about how to set it up with my X16. So much so I've raised a few questions here: -
What's funny is I bought the Gustard because it didn't do that. I had originally bought and returned an SMSL M300 and a Topping E30 as they both had handshake issues when I switched from Amazon Music to Roon DSD music.Hi guys
I got a Gustard DAC X16 second hand and it is really great. I would like to share with you a recent issue i faced, in case someone of you faced it already.
I'm using it with Volumio (tried both on an old PC and on Raspberry Pi 4) and USB connection and play both TIDAL (MQA, etc.) and local FLAC, WAV & DSD files. All fine and no issues.
Trying to optimize it, i purchased also the GUSTARD HIFI Replacement Fuse Nano Alloy High End Fuse Compatible with U16 / C16 / X16 / A18 630mA...
Please no criticism on this ;-)
After I installed it following also the guide on the direction of the fuse, a couple of times when i was switching from TIDAL to local DSD files, i was listening only to noise... Changing DSD file the same. I had to play a FLAC which was played correctly and then DSD were also played correctly.
Raising this to Gustard support, they suggested me to update the USB firmware following the package and directions from the following link:
https://www.mediafire.com/file/vu1j1lm676shas9/GUSTARD_X16_USBFW_programming.zip/file
Has anyone ever tried this or faced similar issues?
Thanks in advance
Thank you Dennis for your response.What's funny is I bought the Gustard because it didn't do that. I had originally bought and returned an SMSL M300 and a Topping E30 as they both had handshake issues when I switched from Amazon Music to Roon DSD music.
I have an updated X16 firmware and I used to have noise when playing DSD and that may be your problem. If you search this thread for my username you will see most of the issues with DSD noise and firmware updates.
Now I have no noise issues and I have tried iMac or Mac Mini via USB and RP4 with Ropieee and Volumio via USB.
I did both updates --- but the "programming" update didn't help. The USB upgrade was easy and it fixed it.Thank you Dennis for your response.
What was the fixing action in your case?
I have read about firmware upgrade but this is for the DAC and requires a programmer to my understanding, while what was suggested to me was a USB firmware upgrade, which does not require a programmer.
Great, thank you! I did apply the USB firmware upgrade, was very simple to do so. I tried to replicate the issue unsuccessfully so far. Fingers crossed!I did both updates --- but the "programming" update didn't help. The USB upgrade was easy and it fixed it.
No ... the sound was unchanged.Great, thank you! I did apply the USB firmware upgrade, was very simple to do so. I tried to replicate the issue unsuccessfully so far. Fingers crossed!
BTW, I'm not sure but i have the feeling that it also sounds different, better, like more depth and stage. Did you notice something like this as well?
Or any information on the fixes/changes applied in this USB firmware?
Yeap.Has anyone ever tried this or faced similar issues?
I believe you are referring to the firmware update to the DAC OS….there’s another fix to the USB port that doesn’t require taking the unit apart That came out the beginning of the yearYeap.
It happened few times after firmware upgrade. I guess this glitch depends of xmos firmware so you have to live with it cause gustard`s firmware update won`t fix it.
So I missed that. Thanks!there’s another fix to the USB port
