Gustard X16 Balanced MQA DAC Review
ArturoKiwi
Can any one suggest XLR cables to purchase on Amazon or any where for that matter?
I just bought a Ricable Magnus xlr, lifetime warranty, really really happy with them.
They are not cheap as the Mogami, but it's an Italian brand that mede their cable professionally and with passion.
I bought an usb cable too, but I didn't test it yet
fabriciom
Madrid, España
230€ for 2 cables???
Veri
On the USB cable page:
"The sound performance is characterized by a marked improvement in the bass range, which acquires depth, and by a better separation in the mid-high range, which gives brightness and detail to voices. The greater control makes the listening more airy and fresh. Certainly the best result is obtained with lossless source files, but the general improvement is perceivable also in PCM". Err. PCM is lossless. Marketing dude dropped the ball
Sorry to say but this is utter nonsense, snake-oil pandering. Hate to say you probably wasted some good money.
Matias
São Paulo, Brazil
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
Blue Jean Cables does nice work.
I have some Amazon basics cables and they have been fine. Are you looking for bling factor, or do you just want to spend as little as needed for competent cables?
Harmonie
France
Everything is ready and can be delivered immediately after passing the MQA certification.
It's nice and welcome to see Gustard's communication at last.
I wish this brand would invest a bit more in PR aso.
The products are (very) good.
But in today's world, we need more.
fabriciom
Madrid, España
Just looking for good cables. No snake oil.
Van Dam seems good but provider is in the UK and they are totally shut down because of the virus.
I might just make the cables myself. If I can source the connectors and cables local.
Doesn't seem to be too difficult.
BDWoody
Chief Cat Herder
Moderator
It's not difficult, it's just a bit of a pain. I've done it, but haven't lately, because I'm a lazy bastard.
fabriciom
Madrid, España
I've found everything at my local electronic shop for about 35€.
I will use the neutrik NC3 M/F XX-B connectors with gold tips.
Shielded mic cable with 2 cores 0,22mm.
nighteagle
This or the d70s? Going to connect it to a topping a90 using xlr. Using sennheiser hd 800s. Source is a computer (usb). Only going to be used for gaming and music listening.Today I am using a topping d50s. Wanna switch to xlr.
Also do they have usb drivers like topping? How is driver updates? Quick releases for Windows if needed?
JohnYang1997
China
Like AKM DAC chip? -> D70s
Don't care? -> Do you like MQA or not? ->
Yes? -> X16
No? -> D30pro
Maybe SU-9 too, but I think X16 is better than SU-9.
dmac6419
USofA
Yes? -> X16
No? -> D30pro
John Yang I'm looking for a streamer, you guys got something in the works for 2021
nighteagle
Yes? -> X16
No? -> D30pro
Dont use mqa atm. Maybe in the future?
Dont know about AKM vs ESS. Sound signature? But guess they sound the same? Clean?
Negatives of the x16
Ess hump. Something to worry about?
Not shipping yet
Negatives of the d70s:
Ouputs more than 4v xlr have to go -2 volume
Costs 150 usd more
Drivers and fast driver updates on new Windows builds if needed is a must.
