I still haven't gone crazy
Smarter Shopping, Better Living! Aliexpress.com
www.aliexpress.com
That cable could be your problem. It seems that you have a counterfeit copy that may not even have the correct termination and balanced impedance. A real Nordost Odin cable from an authorized dealer, as
@Yogi42 suggested, will cost several orders of magnitude more. For example:
While we do not always stock every product in every finish, we can always put something on order for you! And keep in mind, many products are only available through our brick-and-mortar retail store. Give us a ring anytime at 415-614-1118 to place an order or ask us questions, or write to...
audiovisionsf.com
($13,000)
I'm interested in giving AES/EBU a try as well. However, this is the
most I'm willing to spend on the experiment:
https://www.thecableco.com/d-110-digital-cable-aes-ebu.html ($100)
I'd suggest you try one of these or something similar that is known to be made and terminated properly.
Gustard's "NOS" mode really only makes sense if you're upsampling the source stream in your media player software. Feeding it 44.1 kHz content with "NOS" mode will produce significantly rolled-off highs. I suppose if you enjoy that, it's fine, but it's not accurate or how the DAC was intended to be used.
