DualTriode
- Joined
- Oct 24, 2019
- Messages
- 904
- Likes
- 595
I don't just chuckle, I laugh. What MM front end has Amir tested that comes remotely close? Nothing. It's funny actually.
Chasing SINAD numbers with our test gear (you have a QA and an AP don't you?) and overload/specs like that, isn't an example of careful design and considered choices? I say it is- what say you?
But it really doesn't matter. The volume control and stage will be attenuating both the signal AND the noise. So you have an essentially perfect front RIAA stage and the following stages are not limited.
Not that it matters in this case, the 1kHz THD is -118dB (0.00015/0.00013%) and the THD+N is ~-83dB (0.0071%). The specified S/N (A-WTD) was 90dB for phono MM. I tested 90.31dBA (L) and 90.03dBA(R).
By all means, pull out your best MM phono stage and let's see what it can do. Looking forward to it.
Hello,
I do this stuff for entertainment. There is some precision in the numbers. I do like to use real numbers with a dBV scale rather than some variable dBr scale where 0dBr for one DUT is not the is not the same 0dBr for the next brand X DUT.
I am sorting the Pearl3 in a cookie tin on my bench. the gain is not where I want it yet.
So Far:
The P3 has 4 each 2SK209's at the input stage.
Input is 5mv
Gain is 50.39dB
output volts is 1.653Vrms
THD+N is 0.004%
SINAD is 87dB
The above measurements were taken with APx555 analyzer. My expectation is that the limiting factor will be the Turntable MM cartridge. and surface noise
I am still adjusting the gain.
See the P3 FFT with 2SK209 Jfets below.
Yes, I am in agreement that the signal and noise will be attenuated at the line stage or power amplifier. Most of the current crop of electronics has voltage regulators that limit the maximum output voltage.
I have the Benchmark pre-amp sitting on my shelf. The maximum output voltage is 10Vrms. The volume control is interesting in that it is not just a variable voltage divider. It adjust the gain by switching / changing the resistors in the feedback loop.
Thanks DT
