has anyone tested Silent Angel M1T?
blanc
Hi,
has anyone tested Silent Angel M1T? I just wan to know which method gives better audio performance: local hard disk (SSD) or network transport (via switch)?
RandomEar
What do you refer to when talking about "better audio performance"?
EDIT: Ohhh god, the company also sells a "Power Source Purifier" (arguably useless, but OK) and a "Network Purifier" (100% pure snakeoil bullshit).
B
blanc
I would appreciate it if you could evaluate M1T after you use it.
flywood
Chrispy
PNW
Why would one want to use it, let alone run tests on it? What makes it worth seeking out?
kemmler3D
San Francisco
There's no known way for SSD vs. Network to change sound quality in a normal situation. DACs have buffers, this eliminates any possible difference completely.
somebodyelse
So... a Pi 4 plus a digital output, a couple of proprietary bus connections and their own linux-based firmware image.
B
blanc
Thanks. That’s what I want. It seems M1T has a jitter issue. One question: can this issue be solved with asynchronous USB mode? That is if the USB DAC does a reclocking.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
What jitter issue? You find those artifacts at -130dbFS problematic?
B
blanc
Nutul
I have a RPi4 + moOde audio sw + Eversollo DAC-Z8. Total price ~750 EUR.
I can use it with local storage, SMB/NFS shares, NAS, Roon, LMS, Spotify connect, BT, AirPlay 1/2
It can:
play "internet radios"
stream over HTTP
play to BT
serve DLNA and UPnP
play to multi-room
have P/G EQ / DSP et-all with CamillaDSP
Performance-wise, I'd say slightly better. And a little bit cheaper (but then again, the DAC alone is 700...)
HNK23
Yes, I have the Munich M1t, but I can't tell you if there's a difference, because for us it's a pure streamer and it does that perfectly. I've had it for about a year and I bought it because of the sound in combination with my DAC. I previously had a Bluesound Node and the sound was always too flat for me. The Qobuz application in the app is functionally the best I've come across so far, outside of Roon.
tomorry
I've been using the Silent Angel Munich M1T transport for a year now with great satisfaction, coupled with a Sabaj A20D DAC. It is a very usable, flexible system with a very good user interface. It works with Tidal Connect and can easily play any music from NAS and SSD. And I think the sound quality is quite excellent for its price range.
