The T60RP is an orthodynamic planar headphone and is NOT damped electrically at all so damping factor is not an issue.
These headphones need quite a lot of voltage (and current) to be driven loudly.
92dB/mW @ 50 Ohm = 105dB/V and rated 3W.
That last spec says little. Music peaks of 3W is not the same as 3W continuous power.
The Burson can provide around 9V into 50 Ohm = 1.6W output R = 6 Ohm DF= 8.3 current draw = max 180mA
a 50W amp (assumed in 8 Ohm) = 20V = into 50 Ohm = 8W output R= 0.1 Ohm ? DF= 500
a 50W amp (assumed in 4 Ohm) = 14V = 4W output R= 0.1 Ohm ? DF=500
Damping Factor is a non issue, even at 8.3
So the FUN will no doubt drive it fine even with its poor DF (which is a non issue).
I've no idea how BURSON is measuring the output impedance, but I measured
0.39 Ohms for the FUN and about
0.45 Ohms for the PLAY (Amir found about the same output impedance for PLAY). I've used 1 KHz sines of few V RMS...between 25%-50% of amplifier's max. power.
For FUN I needed to find a resistor of less than 4 Ohms to use in parallel with outputs to lower FUN's output voltage from 100%@600Ohms to 90%@<4Ohms, so from 10V RMS to 9V RMS. I would call this a very good dumping factor.
I've also used BANG (2xLM3886TF inside) with FOSTEX T50-RP and Hifiman HE-560 and had no problems driving them both (low gain used as safety) and with a DAC with variable output volume in front of BANG.
I've got perfect compatibility for both FOSTEX T50-RP and Hifiman HE-560 with PLAY and FUN, but also with Matrix HPA-3B as well (4 output transistors/channel).
For moderate listening levels also ASUS Essence One (2xLME49860 @12V) can do the job, same I can say about the Objective2 with a gain of 3-3.5X (careful with the "exploding" NJM4556 output buffers when driving planars!).
For insane people that really want to have lot of power reserve (like >5W/channel @40-50Ohms) I've tested the above cans with Pioneer A-209R and Burson BANG and sound was very good. However, BANG had no background noise, instead A-209R had some noise under quiet environment (Direct drive used, a bit of noise was still there).
Per Tyll's measurements to one of his HE-560 seems that we need about 2.5mW to get to 90dB. Digizoid does this better than me, so based on Tyll's impedance and sensitivity measured I was able to get this:
Listening Loudness Voltage Needed Current Needed Power Needed
Safe 85 dB SPL 0.18 Vrms 4.19 mA 0.75 mW
Moderate 100 dB SPL 1.04 Vrms 24.19 mA 25.15 mW
Fairly Loud 110 dB SPL 3.29 Vrms 76.51 mA 251.72 mW
Very Loud 115 dB SPL 5.85 Vrms 136.05 mA 795.87 mW
Painful 120 dB SPL 10.4 Vrms 241.86 mA 2515.35 mW
So a decent 1W/channel amplifier should drive HE-560 well enough.
AFAIK a headamp needs to be able to drive the cans to about 110-115dB when 0dB signals are used. For highly compressed music that probably means >95dB of average SPL, but for normally recorded music (at the same knob volume position) there should no be more than 85-90dB of average SPL. So the 115dB is just the max. SPL the cans are handled by the amplifier, those peaks for a very short amount of time and not the average SPL our ears get exposed to.
However, for our safety, worth a read:
https://www.innerfidelity.com/conte...-guide-articles-headphones-and-hearing-safety.
