Headphones with the best sound stage 3 Questions
PolkFan
USA, Michigan
I owned several pairs of headphones but i pretty much started on AKG's K7XX and i refuse to ever get a pair that doesn't have the same sound stage or even bigger due to me watching movies and playing games on them just as much as i listen to music.
1. My question is this for under $400 what is some of the best headphones for extremely big sound stage
2. Why don't all games+Movies support HRTF?
3. What makes a stereo headphone achiaive a great sound stage vs just being open back i owned the 6XX and the sound stage was so much smaller then the K7XX's but it was also a open-back. I heard it was the 10K-20K frequency spectrum?
maverickronin
Midwest, USA
Beyer DT990 comes to mind in that price range. The open Audio Technicas tend to have very open soundstages as well
Extra work on on everyone's part. Non-customizable HRTF algorithms are usually not very good or don't work for a wide enough variety of head/ear shapes and sizes. Customizable ones take work from the end user.
It sure would be nice if they were more common.
It's a lot more complicated than simple frequency response. I know some things that can influence it are distance and angle of the driver from the ear, since this introduces moreof your personal pinna transfer function into the sound, but the Senns and AKG's aren't too different in that regard. I think you can also influence it with the semi-porus fabric/paper/mesh that open headphones often have covering holes in their baffles, but I haven't personally experimented with that the way I have with driver distance and angle.
PolkFan
PolkFan
USA, Michigan
Fluffy
That site is like a best friend to me now WOW i have to get some Ananda's like right the F now.
I would take everything there with a grain of salt if I were you. I also initially saw all that theory and thought that they got the soundstage thing nailed down, but in practice this doesn't translate to the actual experience. I think they make too many untested assumptions and basing all the calculations off of those.
Anyway, in my experience there are several factors that contribute to wider sounding soundstage. First of all, drivers that are angled and located more in front of the ear actually sounds narrower. If you push the driver backwards, it makes more of the sound appear to come from the back of the ear, thus enlarging the stage. One of the reasons planars tend to sound wider is because the driver is so large that a lot of the sound hits the ear from the back. Also, drivers that are located farther away from the ear sound wider. As you put drivers more to the side and away from the ear, the stage increases. A simple trick to "widen" any headphone is to put thicker pads, and preferably straight ones rather than angled.
Another factor that I noticed is that more bass usually makes wider stage. I'm not sure why that is, but I think it has to do with how lower frequencies are less directional and the mind thinking that if it hears more bass, it means it's farther away from the source of the sound. You can try using EQ to give a gentle tilt towards the lower frequencies. It works best with the very lowest part of the spectrum, around 20-100 hz. Boosting above that just creates mud.
Openness does contribute to wideness, but as proven by the 600 series from sennheiser and Stax headphones, it's actually less important than the two previous factors. Having the driver far away from the ear in an open design will do more to wideness than a close driver. But having a closed design or just not very open will diminish the effect of a far away driver
In the pursuit of the widest soundstage, there is an important tradeoff to consider - You always trade soundstage for imaging. The wider the soundstage in headphones, the less authentic it is. Basically, the hard stereo separation in headphones is not very realistic, so the wide soundstage is a side effect of the magnified stereo effect. That means that sounds that were supposed to be heard by both ears can sometimes be only heard by one, thus ruining the image illusion that would have existed if you were listening with speakers. I think that's why the HD800 is so successful here – the drivers are far away from the ear and with a super open design, angled forward, with an accentuated treble and almost no resonances or interactions with the cups. All of those factors combine nicely to give a wide sound that also images great. The drivers themselves are good but not too special, and it's the acoustic design that makes that concept work.
solderdude
The Neitherlands
If stereo width indeed could be measured by a 10kHz notch being present in their measurements then one could simply notch all headphones with 10kHz filters and the brain would be fooled into thinking soundstage is wide.
Doesn't happen in reality.
I think (substantial) driver angling, ear-driver distance and accuracy of the driver as well as L-R matching above 2kHz are important.
tomtrp
10khz notch on rtings is from ''Headphone's PRTF = (Frequency Response w/ Pinna) - (Frequency Response w/o Pinna)'' so I don't think 10khz filters alone can effectively create 10khz notch in PRTF, so maybe their model can somehow model the effect of driver angling, ear-driver distance etc.
solderdude
The Neitherlands
It will have some correlation but lets just say that I would not bet my life on it showing actual 'imaging' info.
posvibes
I have read that it is possible, but I have never experienced the sense of the music being in front of me when listening to headphones.
I can get width, and a sense of the music from behind as well as below my ears and even a sleigh height above my head but never from in front of me.
What is the experience of others?
solderdude
The Neitherlands
That seems to vary.
Headtracking and special crossfeed seems to help. Some more than others.
I hear this the same way but have had some experiences when I was listening to music and at the onset of falling asleep heard distinct 3D effects.
Alas I either fall asleep or 'wake up' and its gone again. No luck for me.
I can imagine some folks might be able to pull that trick while fully awake. I envy them.
I can hear, to me worthwhile, differences in stability and separation of instruments. Easier to place and 'follow' them in the stereo image. I call this more effortless or more relaxed listening.
Only the famous 'haircut' is a bit in front and rear. It is also highly recording dependent.
