F1308
- Joined
- May 24, 2020
- Messages
- 1,063
- Likes
- 920
If people like Hegel then it means people prefer the sound of distortion.
...and then they can even announce great savings by having spared the pedal effects !!!
For $2000 amp is this ok ? Benchmark ahb2 is only 1.5 times of this and much more powerful best measured amp on Earth !The amp is not bad, only the DAC is terrible.
Nominal line level is -10dBV or 0.316V RMS. To their defense, they didn't write pre out.
Performance is average, with a healthy peak power, consistent distortion throughout the frequency. It is ok by itself. Of course factoring in price an NCore MP runs circles around it for a fraction of the price, so the H95 is not a good value (performance per price).For $2000 amp is this ok ? Benchmark ahb2 is only 1.5 times of this and much more powerful best measured amp on Earth !
Yes, and while the Yamaha WXA-50 is aging and doesn't have the same # of inputs, it performs the same or better, the Musicast app is reliable and is less that US$500.For $2000 amp is this ok ? Benchmark ahb2 is only 1.5 times of this and much more powerful best measured amp on Earth !
I’m sure @Matias meant the narrow performance rather than the overall value for money, which is obviously not great. BTW as good as the AHB2 is it would likely be indistinguishable from the Hegel under controlled conditions.For $2000 amp is this ok ? Benchmark ahb2 is only 1.5 times of this and much more powerful best measured amp on Earth !
They had to, they were competing head to head with BS Audio!Hegel exceeded my expectations, this is class leading failure
an outside question, anybody know if the distortion being changed after the DAC signal going into the preamp section of an amplifier?Performance is average, with healthy peak power, consistent distortion throughout the frequency. It is ok by itself. Of course factoring in price an NCore MP runs circles around it for a fraction of the price, so the H95 is not a good value (performance per price).
An NC502MP + Topping DAC is a lot better deal.
The DAC is the big issue, the amplifier itself is just average. Not worth the money, but it most likely wont show audible distortion....and then they can even announce great savings by having spared the pedal effects !!!
Because there's no new standard defined? Looks like Hegel didn't pay much attention to this output, and customers are taken by surprise because the product specifications don't mention the reference level.The CD players had been around for 40 years. Why should anyone expect to find levels pre-dating CD on a modern amplifier?
It used to be a standard. Unfortunately there's only chaos now, so the smart thing to do is to use the old -10 dbV reference and add the 12 dB or 18 dB that was foreseen for digital headroom. (A guideline that was respected for about 24 hours, until the first sound engineer found out you can drive the format a lot harder without to much consequences).unfortunately -10 dBV is not a standard in the hifi world, every brand has their own specs
Actualy most audiophiles will tell you the Hegel is a lot better. Benchmark is made by a pro audio gear company, people who only measure but don't listen you knowI’m sure @MatiasBTW as good as the AHB2 is it would likely be indistinguishable from the Hegel under controlled conditions.
The Opera Consonance A100. Opera (used to?) build the Hegel amps.Coming back to Hegel, I think they have a (much cheaper) chinese clone which looks exactly the same (internal and external), without the "sound engine" blue chips... But can't find it anymore... I wonder how it measures.
Tons and tons of reviews at YouTube that praise the Hegel amps!!
I'm sure a lot of people bought a Hegel amp because of this
I know you are joking but actually Benchmark conducts many listening tests along with all the state of the art measurements.Actualy most audiophiles will tell you the Hegel is a lot better. Benchmark is made by a pro audio gear company, people who only measure but don't listen you know
If you know what to listen for and in an ABX easily.Are the described distortions even audible...?
Reviewers are often swayed by the industry and $ and marketing just like everyone is to at least some degree... and fact that amps dont vary the sound all that much leaves a lot of room for the imagination to run wild.Amir's data looks terrible. However, I wonder how so many reviewers can be wrong. Are the described distortions even audible...?
