Help!: DAC Lavaudio DS400 rca connection?
shot4d
Hello
I have a question, I want to buy a Dac to join it as my smsl amplifier with RCA cable.
but my budget now is not much to buy an expensive DAC, I already had a problem with the D10s topping and I didn’t like it, especially because of the problem it has of distortion because it is only powered by a usb cable to the pc and it doesn’t have a separate power supply.
I also found the E30 topping but I have to buy a 5v adapter and with that extra plus the shipment from Amazon to my country everything comes out at 180 dollars, and my budget does not reach that point.
So I found this Dac that I have been told very well about and it is the Lavaudio DS400, but there is a problem and that is that this dac does not have an RCA output, it only has an RCA output coaxial yellow and I don’t know if it’s digital or analog.
I want to connect it with my smsl sp200 amplifier, so I searched amazon for a 1 RCA to 2 RCA cable: https://www.amazon.com/-/es/gp/product/B097BL1R28/ref=ox_sc_act_title_3?smid=AQJZW6JIGRNUD&th=1
and my question is if that connection can work with my amplifier smsl sp200??
LTig
Europe
Coax out certainly is digital.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
Looks you would need to use one of the headphone jacks on the other side with an rca adapter. I don't see any other analog outputs.
Zek
@shot4d Why would you even use the SP200 which is a headphone amplifier when you already have headphone outputs on the DS400?
