Help me pick a great SACD player.
BentonF
Inuvik, Northwest Territories
I’d welcome some advice. I’m considering getting a SACD player. I mostly listen to classical where the material is on average better recorded and prepared without all the modern loudness war antics. A good proportion of the classical CDs are hybrid CD-SACD versions. The number of manufacturers making SACD players is ever shrinking. From what I can see the transport and DAC contribute little to the sonics (as both these elements are highly competent) in the audio chain but it is the analogue output stage than can make a discernible difference in sonic quality. Forgive me, I am not electronically qualified, nor an expert in audio acoustics but I do value your collective advice which is grounded in solid science. I have seen a number of SACD machines but can’t determine from their interiors which have been built using quality parts and well designed analogue stages. What would you pick between say:
Denon DCD-1600NE
Denon DCD-2500NE
Denon DCD-A110
Oppo-205
BentonF
BentonF
DCD-1600NE
JSmith
Algol Perseus
You may want to go through these threads;
JSmith
BentonF
BentonF
JSmith
Thank you for the links. The summary of the review of the much audiophile praised SA-10 is that it is well built but underperforms in measurements given the immense price. So this not something I’d be keen on. I think the foundation for any pricey gear is that it must have a minimum of exemplary measurements.
Mart68
England
unless you have a lot of dedicated SACDs (i.e not hybrids) I'd not bother, just listen to the CD layer, you're not missing anything.
Otherwise if you are prepared to buy used look for a Sony SCD XB790 QS. has multi-channel too if you want that.
Elkerton
What is wrong with the hybrid CD/SACD? I have some 140 and cannot hear anything bad, but have not compared the one against the other with the same performance(s). I don't have any, and have few dedicated SACDs.
Having listened now to multichannel, classical recordings for 2 years, I only wish all of my collection was recorded thus.
BentonF, consider the used market as well, or to play, as I love to do, by a cheap Sony. I will likely do so myself as a backup to my other 2 machines.
Enjoy!
Mart68
England
Nothing, but the SACD layer doesn't sound any different to the CD layer so it's not worth getting a dedicated player just for that - unless they are also multi-channel and you want that facility.
rolloj
Another SACD player you may want to look at are those made by Yamaha. Several models, and prices to choose from. Refurbished B stock units are sometimes available on Ebay.
Elkerton
Listening to classical music with 5 channels is wonderful. The speakers disappear. One is immersed, bathed in sound.
Revel M105s and original PSB passive subs
itz_all_about_the_music
No regrets here having used a Denon DBT-3313UDCI input via "Denon Link" to my AVR-X4000 (used as a pre-pro) for several years. Yes, it's out of production.
Tom C
Wisconsin, USA
Picked up one of these a couple months ago at the local Wally World. Was looking for a 4K player. The SACD capability was a bonus, and it’s the only way to get my Denon AVR to play multichannel SACD. The Denon will play DSD and DSF from USB or net server, but only two-channnel. If you want multichannel DSD from the Denon, it’s only available over HDMI from a player. Couldn’t get it to accept multichannel from dsf files on PC over hdmi. And they don’t tell you that, except deeply buried in the fine print of the owner’s manual.
Sony UBP-x700
DonH56
Monument, CO
^^^ That's what I did recently as a backup for my Oppo. The Sony x700 was $200 on Amazon a few weeks ago so I grabbed one. @Tom C found it $10 cheaper at Wal-Mart -- it was higher there when I looked then so prices vary.
GD Fan
NY, NY USA
Oppo is a no brainer from a performance perspective. But prices have gotten absolutely silly.
Another to possibly consider is the Arcam CDS50. I was happy with one but eventually bought a used Oppo 203 to have video capabilities as well.
dadregga
Help me pick a great SACD player.​
As someone who listens to multichannel classical SACDs, my advice would be to not do this if you want the best.
1. Get a used Sony BDP-S5100 ($35)
2. Rip all your SACD stereo and multichannel layers with SACD-extract ($0)
3. Use Roon to stream the DSF files through a Denon x3600 or equivalent AVR (or any recent MCH DAC with DSD support) and feed the output to whatever amp stage you like. (Roon server box (can be a simple Linux NUC) + Roon endpoint box w/HDMI OUT (can be a simple/cheap Linux NUC)+AVR with HDMI IN)
Nice thing about Roon is it will dynamically resample MCH DSD to MCH PCM for output over the HDMI port, so you don't have to worry about finding an AVR with DSD-HDMI support (pointless, difficult, expensive, you will not hear a difference between DSD properly converted to PCM so it is completely not worth the trouble)
If that's too much effort, or you really want a physical transport, the Oppos are your best bet, but they are $$$ on the secondary market. Most of the current SACD transports are expensive, not very good, and don't have MCH analog out.
al2002
Denon DCD-1600NE
Denon DCD-2500NE
Denon DCD-A110
Oppo-205
My pick of this group would be the Oppo 205, but where do you find one now at a sensible price?
Do you have a DAC that will decode DSD? Then the inexpensive Sony 6700 might be worth a punt. It will play SACD, digital out only.
