Help me understand
Doobrey
My Audiolab 6000CDT has 2 digital outputs, optical and coax. It states that the coaxial output is fed from a differential line driver, what does this mean exactly and does it make it a better output than optical?
JSmith
Algol Perseus
No, both are digital... but optical is immune to noise (EMI/RFI). The differential output driver aspect for the coax output is for the transmission of high-speed signals over coax cables to increase noise immunity basically.
JSmith
DVDdoug
And just to clarify... Any "noise" that gets into the audio is usually analog, and it is possible to get ground-loop noise into the analog circuitry through a digital electrical connection. If you get power line hum or power supply whine, through the digital connection, an optical connection will prevent that.
Any noise in the digital signal that causes noise in the audio is data corruption and might be heard as clicks & pops or audio dropouts. But in general, digital is highly-immune to noise or corruption and it's usually bit-perfect or terrible. ...One flipped bit in your bank account is equally likely to cause a 1-cent error or a billion dollar error, so you don't often get slight corruption or slight data errors.
Doobrey
Doobrey
JSmith
Ah I see, so with optical already being immune to noise id rather just use that then if there’s no additional benefits to coax sending 16/44.1
