NAD C 328 measurements from Stereophile - question
brydon10
I was reading through these measurements of this unit on Stereophile (from 2018) here: Stereophile C 328 measurements
I don't really understand this "The C 328's S/PDIF inputs preserved absolute polarity and locked to datastreams with all sample rates up to 192kHz. A 1kHz digital signal at –12dBFS resulted in an output level of 10V into 8 ohms with the volume control set to "0.0," which suggests that the digital inputs have 6dB too much gain; ie, a digital signal at –6dB will just drive the amplifier into clipping into 8 ohms. This extra gain may well be useful with low-sensitivity headphones, however."
Does that mean you shouldn't turn the volume past -6db when using the digital inputs? I probably wouldn't need to, but if in the case of using some really inefficient speakers I'm just curious. Thanks for any help with this.
Update: I received a reply from NAD about this and here is what they said:
"Thank you for contacting The NAD Electronics Support Crew.
This test was stated with a 1 Khz digital signal, music is more complex than a single frequency signal.
Yes this frequency is used for testing however it may not represent what will happen with real musical content.
I do not think that a general statement can be made to keep the volume under -6db.
I think all the volumes settings will be content dependent.
I hope this helps."
