Help with Burned Nad C298 Amplifier
aravena562
Let me tell you the mistake I made. buy a nad c298 amplifier, which comes with purifi modules. I used it for half an hour and it worked perfectly. then plug it into an amp selector next to other amps I have based on coolgan for comparison. It was the worst mistake I could have made. my selector had a common ground, and I didn't read the manual for the nad c298 and didn't know that it couldn't be connected to a common ground selector. In summary, a tremendous blow and the nad amplifier stopped working, now when I turn it on the LED blinks red and of course it does not make any sound. Of course the problem is absolutely my fault and not anyone's fault, I connected it in a way that I shouldn't have. what should have gone wrong? I live in Chile, I sent it to the technical service but they are waiting for the diagnostic interface to arrive from nad for that amplifier.... I have been waiting for this interface for a month. Excuse the bad English, since my native language is Spanish.
JSmith
Algol Perseus
A short circuit has been created by connecting the terminals to a switch with common ground. This causes a massive over current situation which has probably blown the output stage/transistors.
NAD have used an opposite polarity config in this model to reduce strain on the PSU. The left speaker terminal is probably blue not black to indicate there is no common grounding.
JSmith
Apesbrain
East Coast, USA
Interesting. I did not know that about the blue terminals.
A
aravena562
JSmith
Thanks @JSmith, indeed the terminals are blue, it was a big mistake on my part. if the output stage had failed, it is something that a technician can repair or it will involve changing all the cards in the amplifier. I am very technically ignorant, and I want to have an idea if it can be repaired at a reasonable value or I start to raise money to buy a pair of topping la90
TheBatsEar
Germany
Damn! I feel your pain.
Hope this can be repaired for a few bucks.
TheBatsEar
Germany
I think it would be best to talk to the NAD customer support.
Either they say they repair it for a price or they repair it for free.
A
aravena562
it would be us$2200 for 30 minutes of music..... unfortunately I'm in Chile and their local service is quite limited. He has been with them for a month and I still do not have a diagnosis
