NAD C298 Stereo Amplifier Review
Rate this amplifier:
    Votes: 3 1.1%
    Votes: 31 11.4%
    Votes: 136 50.2%
    Votes: 101 37.3%
Vigovsky
Kyiv, Ukraine
"or the company could issue a board replacement which would more or less be plug n play."
This is partly true, of course.
But even small manufacturers can replace boards, components, modules, etc.
Here is an example regarding my amplifier VR-03B (with Purifi 1ET400A).
New Power Supply Ectifier Board PW-2-PRE for Purifi buffer input stage (2 X OPA1612).
In general, there are no problems replacing components.
By the way, instead of a good encapsulated BV EI transformer, I now install a 2x18V toroidal
transformer specially created for this power line. Toroidal - quieter.
I remain a supporter of classic transformer power supply. I also appreciate the timbre sound of musical instruments (tones).
I continue to improve and optimize the amplifier design...
In general, this is not some kind of special business project.
steadilyfred
I just noticed The Audio Factory (Lenbrook's online outlet store) currently has re-certified NAD C 298 in stock. Looks like all products are covered with a 30-day return and 365-day warranty/exchange policy.
  • US - $1,539
  • Canada - $1,759
I think you can also save an additional 10% on your first purchase if you sign up for their newsletter (sign up at bottom of webpage).
https://theaudiofactory.com/collections/nad-electronics/products/c298-stereo-power-amplifier
Werther44210
Hmmm,
even audiophonic's brand does it better for half the price ... though no dealer/reseller In-between...
Hi,
I discovered this on their site, Audiophonics has very good Purifi amps from what I have seen and with a less elitist price, the main fault of Nad is the price which I find high like the M33 for example. It's good that players like Audiophonics are making this excellent method of class D amplification more popular.
Aventador_SVJ
I use a C298 with a miniDSP SHD (with Roon and Dirac Live) in one of my systems.
Tough to complain...
I too have the C298 with MiniDSP SHD (with Dirac Live) and choose the C298 because of Purifi and the fact it has auto sense switch on and then switches itself off after several minutes of non-use, making it more user friendly than other Purifi amplifier designs.
I'm impressed with the NAD (and the MiniDSP).
roog
UK, Keynsham
@Aventador_SVJ Can I ask is it easy enough to set up Dirac live on the mini DSP please? I am not very IT literate.
roog
UK, Keynsham
Thank you for your reassurance, however I have previously run through the manual and I found it all a bit confusing, also I don’t recall any mention of Dirac.
Perhaps there are YouTube video which might take me through the process step by step?
Sparkles
Ditto.
Bluesound Node digital into MiniDsp Flex XLR into NAD C298.
Node and Flex replaced a NAD C658 and while Dirac was user friendly, tinkering with REW is just fine.
I'll ensure fixed gain as per Amir's review.
VintageFlanker
Paris
For EU fellows...
These rotten terminal blocks are not worthy of a device of this price. nad doesn't care about the world.
last experience with this manufacturer for my part
TomekNet
Warsaw, Poland
I run both NAD C298 and Buckeye power amps in my system (and also Audiophonics gear on Purifi and Hypex). If I were buying power amps again I'd just go all-Buckeye Amps and save some cash.
pogo
Buckeye Purifi Amp:
450w @ 2ohm (peak)
425w @ 4ohm (peak)
225w @ 8ohm (peak)
I prefer the NAD especially because of its power @2 ohms and the possibility of bridging: Link
Werther44210
Having an Audiophonics HPA-S-400 recently purchased (200W at 8Ω, 2x400W at 4Ω), there is the most powerful 500 :
2x500W at 4Ω or 2x250W at 8Ω, I find it good for the price, otherwise at Nad, if we don't look at the money, NAD M23 possibility of bridging:
2*380W at 4Ω
2*200W at 8Ω
pogo
These are the correct measurements for the M23: Link
Werther44210
Thank you, it's more precise, I know this site well, Audiophonics sells the M23 as a reference power amp in Hi Fi and its own as a tighter budget alternative. I took one of theirs because it was mounted on an HC installation with a Denon 8500 having an integrated one on my Hi-Fi installation, I hesitated with the C298, but the price/performance/sound quality ratio was in favor of the HPA- S-400.
EJ3
James Island, SC
There's an interesting review of the old "power envelope" amp they used to have.
This NAD 2200 is still going very well as are 5 of my 6.
I have my main system tri-amped with 3 NAD 2200's (one running bridged mono @8 ohm's for each of 2 Dahlquist M-905's [a 6 ohm load] and 1 running stereo @ 4 ohm's to each of my 2 custom {by me} 4 ohm subs).
The 1 that is not going at this time suffered a giant power surge (from an exploding transformer on the telephone pole outside, the flash INSIDE my house house made momentary shadows on the walls INSIDE my home that also killed the 1350 watt UPS that it's power cord was plugged up to).
I have the amps on their own circuits in the home (there was a small black mark at the power outlet that the UPS plugged into but the 20 amp breaker was not tripped & the circuit tested fine. But I replaced the outlet anyway).
This 1 UPS & the 1 NAD were the only thing damaged in the 3 NAD 2200 system (reminder: each is on it's own 20 amp circuit).
Fortunately Peter (of Quirk Audio [which refurbishes a range of products from companies such as APT Holman, Harmon Kardon, Grommes, Fisher, Kenwood, Marantz, McIntosh, Mitsubishi, NAD, Nakamichi, Onkyo, Pioneer, Revox, Sansui and many others, including both tube and solid state units]. By selecting those products and designs that will reward upgrading and refurbishing, where new components, which as technology has evolved, are often greatly superior to the originals, can be installed, resulting in quite outstanding performance, which otherwise today is only available at the highest echelons, and cost, of specialist audio equipment, allowing one to have a GREAT vintage/classic product in your system),
had one of my other NAD 2200's in for servicing (I send them for general servicing & inspection about every 5 years or so), prioritized getting it finished for me & sent it back to me poste haste so that I could just pull the messed up one out of that system & put the newly serviced one into it's place.
Thank you Peter!
Thank you Peter!
I still have my NAD Power Envelope 3130. It's a very nice sounding work horse of an integrated amplifier.
daniboun
France (Lyon)
Great project ) Reminds me of the Maroon Audio amplifier
