Help with measurement data
TjindarSingh
Pfungstadt
Hi I'm not that good to read measurement data and wondering how this amp behave, they mention snr a weighted don't know what a weighted means please help.
I know the amp is really expensive but let's just discussing the measurement.
TjindarSingh
TjindarSingh
Pfungstadt
How important is the measurement after a certain point? I've heard amps that I loved that doesn't have more than 83db according to the manufacturer and it sounded amazing " class a sugden ia-4".
Eetu
Helsinki
Have a look at this list. 9 Hegel amps listed. Not great performance for the price.
As you said they're likely fine in audible terms, but still why pay that much since there are other nice looking amps out there with better performance and features. Perhaps the NAD M33 if you have 5k to spend.
TjindarSingh
TjindarSingh
Pfungstadt
Tried them switching in between and preferd the Hegel. Have other class d amps that probably measure better.
Sokel
Are you sure?
What's dbr-A stands for?
Sokel
It should means relative to Amplitude. So that in the graph you have the highest signal on the 0 point and it makes the graph easier to read.
edit: @staticV3 was faster than me :)
I know that about dbr.
But what is the difference between the plain one and dbr-A?
Is it some Audio Presision reference as I understand by @staticV3 's post?
staticV3
It's explained in the link I sent you.
On AP analyzers you have dBr-A and dBr-B.
Those are not fixed referenced, but two presets that you can configure to whatever you like.
So dBr (Preset A) and dBr (Preset B)
In any case, they have nothing to do with weighting. Just amplitude references
TjindarSingh
TjindarSingh
Pfungstadt
It also says 105.6 is that when you use the internal dac?
