Chocomel
- Joined
- Feb 18, 2019
- Messages
- 107
- Likes
- 329
Yeah was worried that was the reason. Thanks for respondingUnfortunately Audio Precision software doesn't have that capability.
Amir told me via his review that my beyer t1 was a headless panther. I still like it. May be bias, may be faulty ears. Either way objective is happiness- and I am happy. Mistakes/shit happens and it's ok as long as you are happy with it.This sentence we have heard so often. And I disagree. But I admit it is difficult to explain. It is not about telling you (not you personally, of course) where to spend on or not. But under certain circumstances you got to admit, it was then a mistake, which you normally won't do. You are free to do mistakes, of course.
I was thinking either that, or there is severe variance in treble with these Anandas.Positioning matters a lot for Ananda. Positioning a little back solves most high frequency peaks.
Here is a track with such deep bass: Terje Isungset - Fading Sun
There is deep bass here that most speakers can't reproduce.
In-ear Measurements like for example rtings does would be a great way to confirm it.
Correct.
It all started when Amir was trying to explain the differences between his PEQ and Oratory's PEQ profile, for AKG K371, back in January 29.
So I simply imported Oratory's PEQ profile and made a gif to compare both.
People liked the idea, and here we are...
Here's my thoughts on how to do this:It would also be great to compare the measurements!
Before my purchase, I ran a poll asking if I should get an LCD-2F or Ananda. Well, the Ananda won the polling. So.. should I sell these and try the LCD-2F then?
I am going to go broke trying to find a good set lol
As I stated in that post, the LCD2F would have been a more technical capable headphone if you're ok with EQ (just look at the LCD-X review, which has the same driver arrangement minus the impedance).
What is this? Is this audible or do we hear those identically? Can I measure these capabilities? Or is it again just Head-Fi speach "for believers only"?As I stated in that post, the LCD2F would have been a more technical capable headphone if you're ok with EQ (just look at the LCD-X review, which has the same driver arrangement minus the impedance).
I think it's more interesting comparing measurements of Oratory vs Amir rather than the EQ Curves, because it's the measurements that determine the basis of any EQ, and also reflects how the headphone would sound when at stock without EQ. Yes, you're right, that's how a person could compare the measurements (I've used VirtuixCAD in the past to extract text file data points from a graph - the SPL Trace option of VirtuixCAD).Here's my thoughts on how to do this:
1. The measurement fixtures would have to match from source to source.
Amir used GRAS 45CA-10 since the beginning.
Oratory1990, as far I know, also uses GRAS 45CA-10, so that's good.
But he used different fixtures in the past, so it wouldn't be an apples to apples comparison.
For the Hifiman Ananda, he used "GRAS 43AC/43AG" fixture. (source)
2. For best results, you'll need the raw frequency vs dbSPL for both sources.
Amir attaches his measurements with each review, so that's perfect.
Oratory1990 doesnt include his raw measurements. (example)
So you would have to find this data elsewhere...Jaakko includes this data in his CSV file. (source)
If you can't find the data, you would have to use the 'WebPlotDigitizer' to extract the frequency and dbSPL data, and save it to excel.
Then import both into REW and then simply show both on the same screenshot (or compare each individually and make it a gif).
Is this worth doing? You tell me.
Perhaps another member has tried this already?
No way, LCD-X is a disaster! https://www.audiosciencereview.com/...-x-over-ear-open-back-headphone-review.16777/As I stated in that post, the LCD2F would have been a more technical capable headphone if you're ok with EQ (just look at the LCD-X review, which has the same driver arrangement minus the impedance).
