staticV3
- Joined
- Aug 29, 2019
- Messages
- 8,334
- Likes
- 13,416
You made a small mistake. Filter 6 is supposed to be a "Low shelf filter (Q as Slope)" not "Low shelf filter (Slope in dB)".I like the treble energy of the Oratory EQ, but I added the 40 Hz bump that Amir added, makes it have more low end presents.
Using the Graph window in Peace you can see the difference between the two types and also that Q as slope is the correct one to choose according to oratory's PDF.
If you have a .txt file, simply change "Filter 6: ON LS" to "Filter 6: ON LSC".
