Hifiman Arya Review (headphone)
Rate this headphone:
    Votes: 12 4.0%
    Votes: 57 18.9%
    Votes: 135 44.7%
    Votes: 98 32.5%
HRTF_Enthusiast
IDK, I guess everyone's different. I don't get the sharp "murder treble" and sibilance with the Arya like I got when I had the Audio-Technica ATH-M50Xes (when I had them) or the unmodded Fostex T50rp mkiii's when I still listened to them. However, I do have a class A discrete HP amp that - while revealing - is not annoyingly bright or edgy, along with a neutral but not edgy DAC. Those really do mitigate most of the brightest characteristics of both the Ananda and the Arya for me. The chain counts a great deal in how they sound, IMO.
nothing in that chain is coloring the signal. It'll sound the same a90 and d90.
Ezees
Not. I've owned the Monolith '887, the A90, and the Magnius. I sent both the '887 and the A90 back but kept the Magnius as a backup because it's such a good value, but also in case one of my other amps goes down. The A90 seemed to have a slight mid-bass thickness (or bloat) and a closed-in top end that I didn't quite like. The vocals also sounded somewhat "canned", and not quite as natural as my class AB amps (though I did like it as a preamp to my Emotiva A-100). The '887 sounded more linear and open all the way around but didn't have preamp capabilities. The Magnius split the difference between the two (and it's fully balanced and has a preamp). With the Arya, my class A/AB amps (Magni 3+, Emotiva A-100, Gustard H20) have all proven to sound more natural with vocals, imaging, sound-staging, and trailing edges of musical notes than any of the op amp based amps that I've tried. Not huge differences but still quite noticeable to me.
Hi @amirm! I've two questions:
1. can you describe sound-stageing difference between Arya and you DCA Stealth please?
I think it is superior to Stealth.
HRTF_Enthusiast
That's nothing more than the psychoacoustic illusion from how the headphone feels on your head. Spatial quality discussions should just be replaced with clamp force and pad dimensions.
Ezees
Wow. That's what you say. Not every HP sounds like the HD650's. Some other HP's have qualities that outpace it by quite a bit. I'm listening to my Ananda as I type this (my new Arya is in the mail), and it's far and away a more enjoyable listen than most dynamic cans I've heard. It has excellent bass depth/detail, speed, and spatial imaging characteristics - I can sometimes hear sounds from what seems like behind me. And it's not even as good as the Arya in those areas, IMO.
HRTF_Enthusiast
Only thing far away in ananda is resolution
Ezees
Mine seem to be pretty detailed and resolving. I can hear all the little background instruments, trailing edges of music and vocal detail really easily. Maybe my amp pulls out more detail than the one you used to audition them? Maybe you've lost some upper frequency hearing or midrange sensitivity? Different strokes for different folks though.
HRTF_Enthusiast
funny that you suggest I might have lost midrange sensitivity when the headphone has a ripped out midrange
Amps don't "pull out" detail.
There's only untrained (you) and trained (me).
riffmaker
Haha, I have Aryas and this sometimes happens to me too.
I was looking forward to more speaker-like soundstage and here I am hearing things behind me :D
Ezees
Both Ananda and Arya do this sometimes, Arya more than Ananda. Maybe HFM's egg-shaped planars do this more than the round ones.
Ezees
Guess you'd not know that much about different details being emphasized or attenuated since your primary HP is the 650, which is more mid focused. Other HPs can reproduce both ultra-low bass and high treble along with the oh-so-important midrange. Also, there are amps that easily reveal detail better than others - and/or present details differently. I have a few that do that myself. I bid you adieu, kind sir
HRTF_Enthusiast
I EQ HD650 to flat sub-bass. I have voltage matched blind tested various amps with low distortion and flat frequency response. Have you done the same?
Jimbob54
Got a source that lead you to that conclusion? Probably a subject for a different thread though as we are drifting away from the DUT
HRTF_Enthusiast
What training is this exactly?
This was mostly a retort to the hearing damage accusation I received despite the headphone in question having a ripped out midrange and stabbing peaks in the treble, but I am a Harman certified trained listener based on this.
HRTF_Enthusiast
Only if the dimensions of the pressurized volume of air in a pressure chamber are smaller than the wavelength of sound is sound pressure created by excursion instead of acceleration. Thus, reflected sounds are of no significance in headphones.
