staticV3
- Joined
- Aug 29, 2019
- Messages
- 8,205
- Likes
- 13,199
Sure, I can try it.Yes indeed. I use the same settings as well but kept the 105hz filter at 4.5db and removed the 20hz one and am quite happy with the amount of bass I get. You might like it, you might not, but it is worth experimenting in my opinion.
I am not sure where the -17,25 dB comes from?Yes.
It will not.
I'm a bit confused about this part:
This should be able to go to 0dB.
It could be that you have some kind of limiter in place.
Click on the Option menu. First setting there should be max limit. See what is set there.I am not sure where the -17,25 dB comes from?
It is my Android phone.
Why is the Bluetooth input at - 17.5 dB? Figure out how to get that to near 0 and your problem is solved. And you could then knock the Qudelix volume (the right) below 0db too.Hi guys,
I need your support here.
Please look attached two pictures.
After I have set the EQ, the volume decease :-(
Maybe I should buy a balanced cable for my Qudelix 5K?
89 dB is not loud enough.
Thank you.
I have not make any changes, hmm.Click on the Option menu. First setting there should be max limit. See what is set there.
Hi,Why is the Bluetooth input at - 17.5 dB? Figure out how to get that to near 0 and your problem is solved. And you could then knock the Qudelix volume (the right) below 0db too.
Edit. Late to the party.
The 2 screenshots are from 2 different devices. One was a generic Bluetooth label, the second looks to be an ldac equipped phone?I have not make any changes, hmm.
I have only one phone ;-)The 2 screenshots are from 2 different devices. One was a generic Bluetooth label, the second looks to be an ldac equipped phone?
More importantly: can you go louder now?I have only one phone ;-)
But I have also used my Sony TV with the Qudelix.
Was the first screenshot with the TV connected instead by any chance?I have only one phone ;-)
I am not sure?Was the first screenshot with the TV connected instead by any chance?
Take a screenshot of the app screen when definitely connect and playing from the TV and the same when definitely playing from your phone. The labels for the bt source will be different.I am not sure?
I cannot se my TV settings/measurement on my phone?
Yes, the sound is louder now playing with my Android phone.More importantly: can you go louder now?
What is the question?I might be asking stupidly, but the Qudelix offers 2.5mm 240mW per channel.
Please look at the RMS on this picture.
841 mV.
How can the Qudelix play 841 mV, when it can only play 3.5mm 80mW per channel per channel.What is the question?
VHow can the Qudelix play 841 mV, when it can only play 3.5mm 80mW per channel per channel.
