- Joined
- Feb 23, 2016
- Messages
- 20,861
- Likes
- 37,844
- Thread Starter
- #21
So the change at 50 seconds was from covering the DiMo membrane covered hole? BTW, what is the material of the membrane?
EDIT to add:
Okay found what the membrane is.
Whereas most simple flutes have only a blowing hole (known as chui kong (吹孔) in Chinese) and finger-holes, the dizi has a very different additional hole, called a mo kong (膜孔), between the embouchure and finger-holes. A special membrane called dimo (笛膜, lit. "di membrane"), made from an almost tissue-like shaving of reed (made from the inner skin of bamboo cells), is made taut and glued over this hole, traditionally with a substance called ejiao, an animal glue. Garlic juice may also be used to adhere the dimo, but it is not recommended as a permanent replacement. This application process, in which fine wrinkles are created in the centre of the dimo to create a penetrating buzzy timbre, is an art form in itself.
The dimo covered mokong has a distinctive resonating effect on the sound produced by the dizi, making it brighter and louder, and adding harmonics to give the final tone a buzzing, nasal quality. Dizi have a relatively large range, covering about two-and-a-quarter octaves.
EDIT to add:
