How does a low ohm headset consume less power? How is this related to the amp?
D
DoDo
should be no problem.
180mW in 80 Ohm, 120mW in 250 Ohm
İf id4 Mk2 has 20 ohm headphone output impedance ? Still should be no problem with 80 ohm dt 770 pro ? Because id4 Mk 1'' has 20 ohm headphone output ohm. In audient review videos, there is 20 ohm headphone output id 4 MK1 and max 40 ohm headphones using together.
solderdude
The Neitherlands
Is no problem for the DT770-80.
You will get 0.3dB more bass (around 100Hz)
D
DoDo
[QUOTE = "solderdude, post: 657825, üye: 2693"] DT770-80 için sorun değil.
0,3dB daha fazla bas elde edeceksiniz (yaklaşık 100 Hz) [/ QUOTE]
Thank you so much. :)
carlo
I've been reading around trying to understand which are the FR and tonal differences between DT770 pro 80 ohm vs. 250 ohms model.
Some say that 250 model sound a bit less harsh in the trebles compared to the 80 ohms, some say the opposite.
From @solderdude table on diyaudioheaven it doesn't seem to be too much of a difference in driving both models by a sound card or amp, so I think the choice should be made upon sonic features. I'm also considering Akg 371 or 361...in case of the former the price is the same as DT770 so a comparison needs to be made.
solderdude
The Neitherlands
Only your ears and head (comfort) can tell you what the correct choice for you is. Measurements are just an indicator and do not tell the whole story as pinna, ear canal, positioning, seal (acoustical) as well as interpretation of the brain is involved.
Relation between electronics is much tighter than acoustics.
