How to best EQ Headphones on the go? e.g with iPhone
Bjpenn88
I notice that on a some of the headphone reviews, certain headphones are only recommended with certain EQ settings. I know it is fairly straight forward to EQ using software in Windows. However for "on the go" listening e.g when using Bose QC35 II on the go with an iPhone - is it possible/practical to EQ to the level recommended in Amir's reviews for "on the go" listening? I know Spotify has built in equaliser on iPhone - would this be sufficient for equalisation or is it too basic to adjust to the level of detail indicated in Amirs reviews generally?
beeface
I looked at the equaliser on the Spotify iPhone app recently and was disappointed that the y-axis isn't labelled with db values. I felt annoyed and just left it flat. :)
Unfortunately, as far as I can tell, there is no way to implement system-wide EQ on an iPhone without jailbreaking it.
B
Bjpenn88
Remember for $110 you could get a Qudelix 5k. PEQ solved - for any HP!:)
PS- not Apple here. Qudelix 'does' work with ios? Or not? :(
Thanks Qudelix looks promising, also on a side note potentially better than Fiio BTR5 for amplifying wired headphones. I wonder if it will be able to run Aeon RT Closed Headphone
Cahudson42
I found running my HE400i single ended while not bad, didn't leave enough headroom for loud orchestral classics. Switching to Balanced was much better -plenty of Headroom (twice the voltage, 4x the power).
Run your Aeon Balanced..but the 13ohm impedance and inefficiency of the Aeon might be a bit much. If so, you can always run the Qudelix thru a $100 Heresy etc. then Aeon..
sweetchaos
The Curator
BC, Canada
'Neutron Music Player' is the only PEQ-capable app for iOS.
Plus, they recently (on Feb 16) got an update, so you can use any of AutoEQ's +5000 presets. (source)
https://apps.apple.com/us/app/neutron-music-player/id766858884
'Boom Music Player' supports either 8-band or 16-band GEQ profiles only. (source)
It doesnt support PEQ profiles.
https://apps.apple.com/us/app/boom-music-player-equalizer/id1065511007
Alternatively, a US$100 PEQ-capable hardware solution that works best is...
Qudelix-5K
Review: https://www.audiosciencereview.com/...qudelix-5k-bluetooth-dac-headphone-amp.17386/
svenz
London
Roon will let you create parametric EQ and stream to your iPhone. I do that at home sometimes. No remote play though (come on Roon, get with the times already :p).
Acerun
San Francisco
Dan Clark mentioned in the Aeon RT thread that 230mw was plenty to drive the Aeon RT at reasonable listening levels.
Garrincha
Qudelix-5K
This Neutron Music Player allows to load presets like SoundSource on a MAC? Is it possible to combine it with streaming from Qobuz? Is it easy and straightforward to use?
Oratory mentions the Capriccio Pro Player, is this also an alternative?
