How to connect 2 speakers and a sub to this amp, connector image incl.
FunkeXMix
Hi all!
I am new at how to connect subs and would appreciate the help. Can you connect a sub and two speakers to this A800? Or do you need a separate one just for the sub, if so isnt the power from this amp overkill for just subs? I read the manual, but didn't find the answer to this.
Thanks!
sarumbear
A subwoofer is a speaker by itself that you add to a two speaker stereo system. It’s called a 2.1 setup, the 2.0 being standard stereo. Each speaker requires an amplifier channel by itself, hence you need a third mono amplifier for the subwoofer. This is why majority of subwoofers are active with an inbuilt amplifier.
If you let us know your subwoofer maybe we can guide you more in detail.
DVDdoug
Normally the sub has its own amplifier and most "home theater" subs are active/powered with their own built-in amp.
And a "proper" setup also has a crossover to send just the bass to the subwoofer amplifier and to filter-out the bass going to the main speaker amp. That's part of the "bass management" built-into home theater receivers or there are stand-alone active crossovers. Or as a compromise many active subwoofers have a low-pass filter and the bass can go to the main speakers also. Or I believe there are some subs with a full-crossover and line outputs for the left & right channels.
Or there are pro amplifiers with DSP, so one amp can be configured for high-pass and another for low-pass.
F
FunkeXMix
'And a "proper" setup also has a crossover to send just the bass to the subwoofer' Can't this be done on the software player side? Jriver player has this feature:
F
FunkeXMix
Don't have a sub yet, just learnin. Thanks!
F
FunkeXMix
So did I get you right, the amp in the image only has 2 channel outputs from the looks of it, which would be taken up by the speakers. It needs one more output to be able to connect a sub to it? Even if the sub is powered.
Zek
Berwhale
Generally speaking, you would not connect a powered sub to this amp because most powered subs accept a line level input and this amp has no line level output. The exception would be with a sub like my REL Quake which has a 'Hi Level' input which can be fed directly from the speaker terminals (in addition to the speakers being connected)...
F
FunkeXMix
Thanks, I am gonna try that!
