Hum from my Tube amp (300B) - Please help!
Saffy
Miami
How to eliminate hum from my 300B amp?
I've tried both a cheater-plug, and disconnected everything except amp and speakers - didn't help
Any suggestions are most welcome
Thanks
raindance
You probably need to adjust the hum balancing potentiometer or otherwise balance the heater grounding path. Is the hum about the same in both channels?
How much hum is there (from how far away can you hear it?) and what speakers are you using? 300B amps are not typically 100% hum free.
Unless something else is faulty, of course. Bad tubes, bad power supply capacitors, bad rectifier, the list goes on.
kevinh
Since the 300B is a DSirect Heated Triode you best bet is to adjust the bias on the tube, like raindance said.
raindance
I wasn't referring to bias. Commonly 300B tubes are used in cathode bias circuits and bias isn't adjustable. But hum balance should be. Does it have adjustments?
Of course, bias could be an issue, depends on the design :)
Saffy
Saffy
Miami
Thanks, no serviceable parts or adjustments available. Hum only heard from 12" away from speaker cone at 6/10 volume. Amp fairly new as are tubes. Rectifier appears fine, though is the weak part of the design. Tried other outlets with no success. Thank you
SIY
Alfred, NY
Who made the amp? Not everyone grounds things properly, and layout can also impact things negatively..
Is the hum a pure low tone or does it have some buzziness to it?
Saffy
Saffy
Miami
Audio Nirvana, yes there is definitely some buzziness to the hum.
SIY
Alfred, NY
OK, that points more to grounding than transformer pickup. Same in both channels?
raindance
I looked at a photo of the inside and it appears to use DC heaters, so no balancing issue. Maybe it just is the way it is. Does it sound OK?
raindance
You should also make sure it's designed for the USA mains voltage (120 volts +) and not 110 volts. It may seem trivial, but 10% high on heater voltage is bad. 10% high on HT is very bad and can blow smoothing caps on switch on. It also causes a cathode bias amp to run too "hot" and can cause hum and premature tube failure.
zelig
There is no cure for an indecisive amp.
raindance
And hum balance pots are possible with DC heaters, so there's that. There's a discussion at the asylum on this amp.
Saffy
Saffy
Miami
Its for sure designed for the US
Saffy
Saffy
Miami
Yes same both channels, actually sounds better with cheater plug om PC
Saffy
Saffy
Miami
The actual transformers hum on start-up, then the hum source goes away after a few minutes. I will try switching out rectifier tomorrow to see if that makes a difference
Saffy
Saffy
Miami
Hi All, I still have a low frequency hum through my speakers using an Audio Nirvana 300b amp. The hum was not always there. Cheater plug helped, and have gone over my PCs and interconnects and can't find the culprit.. Any suggestions?
