Does the amp have a built-in volume control? If yes, does the hum go away if you turn the volume to minimum? How about if you turn it to maximum?
If the amp does not have a built-in volume control, does the hum go away if you short the input? I.e. connect the RCA centre conductor to the RCA shell.
If you have no hum with the inputs shorted (or volume at minimum), the amp is not likely to blame. The only exception would be if you have zero hum when the volume is at minimum or maximum, but you have hum at intermediate settings of the pot. In that case you'll probably find that it's worse with the volume around 2 o'clock (-6 dB). In that specific case, you can probably get rid of the hum by grounding any metal of the volume potentiometer.
If you have hum when the volume is at minimum (or the amp input is shorted), the hum is either getting in through the heaters, the bias, or the B+. If you're running AC on the 300B filament, change it to a 5.0 V DC filament regulator. If you still have hum, I'd probably go after the B+. A high-voltage regulator such as the 21st Century Maida Regulator can be helpful here.
Tom
Tom
