Hypex Announces New and Improved NCOREx Class-D Amplifier Technology
boXem
Europe
I mean it's kind of sink or swim time for them isn't it? Purifi is rapidly diversifying from not just a SOTA amp module but also SOTA speakers, and developing a SMPS should be fairly trivial for them so...
If they bought IP from Purifi they might be able to poke around and learn some things, but they wouldn't be able to use them (if the 'cleanroom reverse engineering' I read on here earlier was right). And having a few hints here and there isn't as advantageous as understanding the whole thing. So they have to make a go for it on their own, learn what they can along the way, and see if they can understand the whole well enough to beat Purifi (or at least remain competitive).
For the moment, the advantage of Hypex over Purifi is pricing power. Something tells me that this will not change anytime soon and that is making a huge difference when talking to the big boys.
The Purifi IP I was talking about is the ability to have a complete mathematical model of the amplifier. This allows to be less conservative on the feedback loop parameters ensuring the ultra high performance we all know about while running extremely cold.
Hypex do not have this ability, the math they use has been published by Bruno P. long time ago.
daniboun
France (Lyon)
Very interesting but on a marketing level, Hypex was smart in proposing a new module packaged as a Purifi Module.
It will be necessary to add an additional power supply (probably an SMPS1200AXXX) seems the Buffers are included inside the module )
However, I hope that they will remain competitive in terms of price... that's the whole point of the old NC500MP and other NCXXXMP modules.
The real question being, how much will we pay to gain in performance?
In the end we can almost understand that this module will work a bit like the Hypex NC400 and NC500, an integrated Buffer and an external power supply for "imaging")
boXem
Europe
They proposed a new module packaged as their existing module. https://www.hypex.nl/product/nc500-oem/50
Purifi was smart enough to propose their module packaged as an Hypex module. Not sure if it was a Purifi decision or a NAD requirement BTW.
Vacceo
Beyond technical excellence, it seems like the audible quality should be the same with the same source and speakers... Or shouldn't it be?
The other aspect is heating and power consumption. How are they different in that regard?
pma
Prague
Let's not forget that the new hotness in audiophile amps is to pair a Purifi or Ncore module with a poorly-designed tube front-end buffer ...
:D
This has always been on the table. I have been receiving same question regarding pairing of the tube front-end with low distortion class A output stage. You get the best of both worlds at once, highest + lowest distortion in one! A good suggestion for an ASR open-project, what do you think? ;)
pma
Prague
The new NCx500OEM. Only 2 frequencies shown, and assuming the better one is 1kHz and the worst one is 6kHz, and assuming 100Hz is the same as 1kHz. It is all gone better, it's just that 1kHz improved more than 6kHz.
Measured with @22kHz BW, right? How about HF linearity with higher BW? (Yes we are talking about inaudible, we all know that, just tech-talk)
Vacceo
:D
The only good distortion is the one used in creating artistic sound. For reproduction, the best distortion is the one that does not exist.
boXem
Europe
Technical excellence allows to run cooler (less losses) with better measured performance. 1.7W idling losses vs 5W is 66% better.
Vacceo
So the effective difference for the customer (let's say, me) between a Hypex and a Purifi based amp is that Slayer will sound equally well, but Purify will waste less electricity.
I'm not mocking it, on the contrary. Less waste in multi channel and for an amp in a rack is amazing news.
boXem
Europe
There is one point beyond technical excellence where Hypex and Purifi differ. It is their low pass behavior. Hypex are 1st order, Purifi 2nd order.
The effect is that in the audible band, the Purifi behave like a high bandwidth amplifier, not the case for Hypex. Audibility of this is beyond my competency.
Matias
Matias
São Paulo, Brazil
From what I read again, Hypex raised the upper f3 from 50 to 80 kHz, against 60 kHz from Purifi? Not that it matters but still.
TheBatsEar
Germany
Perfect amplification of tube distortions isn't a dream anymore! What a time to be alive :cool:
From the link:
audioXpress is looking forward to the challenge of measuring and reviewing this new Hypex NCx500 OEM module. For now, Niels Burema recommends that judgements should not be just focused on measurements. "We believe listening tests to be more valuable than certain measurements. Even if some setting showed better measurements, if it sounds less than we expect, we would still choose another setting. This process has taken many months, until we were certain that we could get an absolutely wonderful module."
I'm glad they tuned the Hypex NCx500N modules by ear. Everything else wouldn't make sense, right?
Assuming these new Hypex amps are reasonably priced (competitive with Purifi), then is this not the golden age?
It sure is, bud, it sure is. All we need now is to lift the OEM restrictions. Only partners are allowed to buy modules and they are only allowed to sell them if they are integrated., means, they are only allowed to sell complete amps. In the beginning that worked, but then they had to support end users and that they didn't want.
boXem
Europe
The Purifi having a second order behavior, you need to take the -6dB point to know the corner frequency, that is 80 kHz.
If you want to compare in the audible band, the Hypex is at -0.25 dB @ 20 kHz, the Purifi is still perfectly flat at the same frequency.
As you write, not that it matters... :)
RandomEar
Sources:
boXem
Europe
Sources:
Nice! one has to keep in mind that the gain of the different modules is different, strongly influencing the N from the THD+N. The NC400 is 26 dB, the others are around 13 dB. We do not know for the NCx500, but the ultra low noise makes me suspect that this measurement is with buffer bypassed.
RandomEar
True. Sadly, it's always tricky to get that info : |
F
freemansteve
Guest
We seem to be in the midst of Class-D SINAD wars.
While the main contenders battle with each other, leaving all the old tech dying in a ditch in terms of price/performance and energy efficiency, let's hope it not just an excuse to push prices up for marginal returns in sonic quality....
Vortex
Central Europe
Why would this matter even a bit?
Just wanted to ask the same:
1. Does it really make sense ? (No offense but "old" NCORE is already soo good and there's Purifi at another level, or still not there ?)
2. It's still an analog ClassD, right ? (Not a fully digital one like so called powerDACs)
Vortex
Central Europe
Can't wait for more "old"-NCORE standalone modules appear in the DIY lineup, ditching those UcD-s there.
