Hypex NCx500 Class D Amplifier Review
Rate this amplifier:
    Votes: 3 0.6%
    Votes: 6 1.3%
    Votes: 56 12.0%
    Votes: 400 86.0%
pma
Prague
I'm going to send Amir a wire in a box and call it an 'ultra low gain amplifier'. OEM DIY Prototype assembly of course. That should get top of the SINAD chart.
John, you have stolen my idea!
I was thinking about exactly same thing, yesterday. Maybe with 100 pF foil capacitor added.
xaxxon
What you've just said is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this forum is now dumber for having listened to it. I award you no points, and may God have mercy on your soul.
I thought it was funny.
HarmonicTHD
Updated the review with new suite with buffer enabled (27 dB):
Thanks.
Could you also publish the SINAD over Power graph please? Would be interesting in light that Buckeye is currently investigating the influence of its buffer on SINAD vs Power. Thx.
Thanks.
See the first post which is now updated.
Blumlein 88
You know a great use for this amp unbuffered with only 12 db of gain? Heh, heh, heh.......
Use a low powered triode tube amp (valve amps to some) to feed into it. Then you get your tube sound and 400 watts of clean cool power. Load the tube amp outputs with an 8 ohm 20 watt resistor and use 15-40 watt amps. You'll have your cake and eat it too!
You could also use SETs, but some of them won't have enough voltage. Well they might from a 16 ohm tap. In any case you'll get 8 times or 16 times the power out that you put into it depending upon whether it is a 4 ohm or 8 ohm speaker you connect. Plus load intolerance. You could even include some coils or caps along with your 8 ohm dummy load for some crude EQ.
ZgSTar
I can't imagine any stereo system that 4 of those can't drive perfectly or am I missing something?
DonH56
Monument, CO
@amirm : Given the lower distortion at HF with buffer, is it possible the AP is not happy driving the HF input load of the bufferless amp? Or maybe the amp itself needs a lower HF impedance drive?
Curious - Don
Fidji
So which one is better? Purifi (stronger one) or new HYPEX?
restorer-john
That was one of my guesses Don. I can try to simulate it with 600 ohm load and see if distortion rises the same way.
Measure the input impedance of the unbuffered amplifier vs frequency first. Many/most amplifiers' input impedance falls significantly at high frequencies. I wouldn't be surprised to see it fall under 1k above 15kHz.
Hence my comment about the poor AP needing a buffer.
Waxx
Wodecq, Hainaut, Belgium
And the first finished amps are in store i see, Rouge Audio Design (IT), who did sell OEM amp board from Hypex (and Purifi and Icepower) launghed the N-7X with 2 NCx500 boards for 1385€ excl VAT. They use OPA1612 opamps as buffer and the Hypex HxR discrete voltage regulators and the Hypex SMPS1200A700 PSU. So very stock...
Audiophonics (FR) is also busy developping their take on it i hear from people close to the guy behind it, and so is Sound Import/SoundImpress (NL) are taking a look at it. So most of the usual suspects in Europe will soon have amps based on this board it seems. ;)
restorer-john
The Rouge (or is that Rogue?) Audio quoted S/N is somewhat 'optimistic' at 136dB...
Waxx
It's Rouge (red in French), not Rogue. They are based in Roma, Italy, but like many Italians it seems that they aslo speak French.
French used to be the upperclass language all over Europe for centuries untill +/- 100 years ago (WOI) and in certain Italian (and not only Italian) upper class envirroments it's still like that. A lot of higher class European brands still prefer French names because it's more "chique" (showing of high class) like we call it here... I don't know that is the reason why they carry a French name, but it could be the reason...
