Hypex Nilai500DIY Amplifier Review
Rate this amplifier:
    Votes: 5 1.3%
    Votes: 14 3.6%
    Votes: 76 19.8%
    Votes: 289 75.3%
boXem
Europe
but. what specifically do you think makes the Purifi "more polished"?
This doesn't exist on the Purifi, indicating a slightly better handling of the control loop:
This is flat on the Purifi, indicating a slightly better handling of the distortion phenomena:
There is also this "10 kHz forest" to be understood. If this would be due to EMI, the Purifi would clearly be superior on this aspect.
prerich
Seems like another great power amp (with a lot of power). Bravo Zulu (BZ)
Rick Sykora
Stow, Ohio USA
Is any of this audible and reproduced consistently?
Seems a lot of hairsplitting when the NCoreX 500 is delivering more power output vs 1ET400A.
Is there another 10 kHz forest that was not due to Amir’s open case?
pma
Prague
Black track, THD+N vs. level, there is a measurement bug near 10W. Not the amplifier issue. Sometimes it happens and one needs to repeat the measurement to get rid off it.
boXem
Europe
Please re-read my initial post...
I missed this one. So the Purifi is clearly superior on the EMI aspect.
Oh, do you mean that Hypex published buggy measurements on their datasheet?
Rick Sykora
Stow, Ohio USA
@boXem not sure which initial post you mean?
I did not know the source of your graphs but am still pragmatic about claims of superiority when measurement minutiae is in question.
If it is not audibly meaningful, not sure why I would want one vs the other (and I own most of them).:)
p.s. btw, all the NCoreX data sheets I have are marked PRELIMINARY
BR52
Germany
I see here only one jumper for the gain selection, is this possible after the "conversion" balanced
to single ended? I' still curious about the input impedance in the different gains?????
boXem
Europe
Most probably the value of the "gain" resistor from the instrumentation amplifier is switched between value 1, value 2 and open.
BR52
Germany
If we know the input resistances we know more to discuss.
beefkabob
Since distortion rises so much with power at 10khz and above, it would be interesting to see a power comparison on multi-tone with a cap of 100db SINAD or .001% THD+N. I'm not sure of the math and if SINAD/THD+N can be calculated that way, so maybe just cap where actual distortion hits 100db. I think that would be an interesting comparison point between amps. It doesn't have to be 100db. It could be 96db, since that's 16-bit's max. Then we'd know "audio perfection" at full power, or something similar.
Dunlavyphile
Seattle
Bummer, I just learned that the faceplates offered on Deer Creek Audio do not fit the new Nilai kits. Sorry about the misinformation. I imagine compatible faceplates will become available at some point.
mppix
NAD 2200 brochure:
more:
Whether these Nilai units would like being bridged due to the (-) return actually having feedback paths, I don't know. NAD managed to achieve decent performance with the Purifi units in bridge mode, although IIRC Purifi didn't recommend it.
It would be interesting to actually measure what gains in various parameters are to be had on the same amp (common supply) by conventional and one channel inverted topologies. With SMPS supplies, there would be much less to gain IMO as compared to a transformer based supply as the SMPS is already operating and replenishing the PSU caps at several hundred kHz, not 100/120Hz.
These Nilai performance numbers are spectacular enough as they stand. :)
Is it possible that this matters only if the amp is single ended? .. and the supply provides +/-Vdc centered on GND.
I always thought the Hypex amps are balanced (H-bridge) but I could be wrong.
mppix
Yes, by tweaking the value of resistor R141. Complete removal is lowest gain.
Awesome. Is there somewhere a description or discussion for this?
(I don't want to take over this thread)
