I have a UMC22, is the headphone output powerful enough to run a pair of 250ohm headphones?
woolfy
I have been using my UMC22 for a while and I am debating whether it is worth it upgrading to a separate amp (Schiit Magni 3/Heresy) to power my DT990s 250ohm. I was just wondering if it is worth the upgrade. I plan on doing this by either doing 3.5mm to RCA from the audio interface, or the inbuilt DAC on my motherboard.
solderdude
The Neitherlands
For high impedance headphones having a separate headphone amplifier can be beneficial when you either can not go loud enough or the sound gets 'grungy' at louder than average listening levels.
woolfy
woolfy
I am able to get the volume that I need, and there is no 'grungyness', so would there be a point in getting a seperate amp?
solderdude
The Neitherlands
most likely ...Nope.
charleski
Manchester UK
In general, small chip-amp headphone outputs fall down when driving low-impedance headphones, but do fine on higher impedances.
