I need a straight answer on Bluetooth sound quality
JSmith
Algol Perseus
To connect up to the vehicle’s audio system using your smartphone, you can opt for a wireless connection over Bluetooth where the SBC and AAC codecs are supported only, or opt for higher-fidelity playback by using a wired USB connection instead. Here, both Android Auto and Apple CarPlay are supported through the infotainment system.
at least AAC
SBC320 kbps16 bit48.0 kHz2003
AAC264 kbps16 bit44.1 kHz2015
JSmith
BeerBear
I don't know what that chart is supposed to mean.
Just to be clear: SBC's higher max bitrate doesn't mean it has better audio quality. AAC can produce better quality even at a lower bitrate.
The encoder used makes a big difference, however. But seeing how OP has an iPhone, I'm pretty sure that the AAC encoder will be good. Whereas with Android phones the implementations vary and you're not guaranteed good quality when using BT with AAC.
MaxBuck
SoCal, Baby!
Car audio is such a crapshoot. Subjectively, I haven't heard a system I thought sounded better than my wife's old Volvo XC60 (2014 model). I have no idea who even made the thing, but it was a whole lot better IMO than the Burmester in her current Mercedes or the several "high-end" Harman systems in my own BMWs. So much of all this depends on the sonic characteristics of the enclosure - i.e., the vehicle's cabin.
DonR
Vancouver(ish)
We always say the most important aspect after the source material is the room or car interior in this case. It must be a reflection nightmare inside a car.
Vacceo
It would make more sense (well, not financially...) to upgrade the car's audio capabilities with dampening, better speakers and DSP. I have a current-gen Kia Rio GT and, while the stock system was decent, it improved immensely with proper dampening and deadening of the car doors and better speakers, driven by a DSP capable amp that allowed for calibration.
Dampening makes a massive difference, even more if you drive a lot. Less noise from the tire contact and engine means a lot less stress.
Better sounding music, is, of course, the other great part.
rwortman
Damping. If you want dampening, leave the windows open in the rain.
NTK
US East
rwortman
Industry misuse is still misuse. To reduce the amplitude is damping. A piano does not have a dampening pedal.
Vict0r
The Netherlands
Hahaha sorry, English isn't my first language. Thanks.
JSmith
Algol Perseus
I was just confirming what you said in reference to AAC being available for the OP, as previously I posted SBC only for the Meridian car audio system.
Yes that's basically what I posted earlier.
JSmith
