- Joined
- Oct 11, 2018
- Messages
- 3,741
- Likes
- 6,460
10-4Removable headshell. Compared to single piece arm like for example the Rega 250/300 etc.
Thor
Thor
Thor
That's just a common audiophile myth.
Korf debunked that myth with measurements on headshells ... a Jelco HS-25 was better than Rega tonearm headshell.
SME uses removable headshells ... i doubt SME do crappy stuff
All that bad marketing from certain manufacturers to sell more, is just hilarious ... as what they said against the Technics direct drive ... come on.
I think @Frank Dernie was doing this sort of measurement at Garrard, back in the day. From his posts, that's where I first encountered the idea of resonances from a removable shell--resonances that you didn't get with a fixed arm.That's just a common audiophile myth.
SME has at times offered removable headshells, fixed connections, and even removable wands. The latter you could get with an integrated Ortofon Concorde cartridge.SME uses removable headshells ... i doubt SME do crappy stuff
Alas, it is not. We are dealing with resonant mechanical systems here.
Thor
I did not suggest rigid arms were better. I suggested that for the DL-103 a rigid arm is a poor match.
I wrote nothing about removable headshell's being bad.
Funny all this given I recommend a Technics 1210 with it's non-rigid arm as a good match for a Denon DL-103 cartridge.
And somehow everyone jumps on what I write to make an argument out of it that states in different ways what I wrote.
Thor
From practical, day to day, use, I always prefer a removable headshell. If you never change cartridges, it's probably not much of an ergonomic issue.
No it isn’t.That's just a common audiophile myth.
FWIW I was only concerned by anything which showed up on the cartridge output, not any random vibration anywhere else.
To: Bernard23
If you can get or make yourself a USB to a suitable DC-jack cable you could power Ifi Zen Phono from a power bank. That would rule out the possible hum issues from mains.
I have no issues with hum or noise with my Zen Phono but I'm thinking about trying to run it from a power bank.
but the cartridge is in touch with the headshell, not with the tonearm itself ... the headshell is the platform for the cartridge and where you have the "vibration anywhere" results.
The measurement is about the "anywhere".
you can have a bad compliance cartridge / tonearm - headshell system and the cartridge output can be worst with a better tonearm - headshell.
That is more or less the opposite of what happens. A removable headshell creates a mechanical break where resonances are damped.
This simply shows a lack of understanding of dynamic systems and how pickup cartridges work, I'm afraid.
This is, and has been, the problem with discussions I have seen on the interent and magazines about record players for decades. It isn't that simple.It also makes sense from a simple mechanical engineering view.
People, even some engineers, apply static thinking to dynamic systems because they are hard to "visualise". Even one of my old engineering bosses 50 years ago told me he saw what the maths said but couldn't get his head round it. As a young engineer I was used to installations where, say, a motor, speed reducer and pump were all chosen by an application engineer based on power and flow requirements, assembled together and had a vibration problem because the assembly had a resonance in the running range which none of the individual components had.
Dynamic systems are complex and thinking of them the way many people do just leads to wrong conclusions IME, I'm afraid, but they are ubiquitous.
Record players have always been complex assemblies and, it seems to me, are less well generally understood than they were 50 years ago, probably due to the amount of misinformation in the internet nowadays.
This is a common set of non sequiturs, based on an absence of education in the basic physics, I suspect.Let's keep it simple.
We have a mostly fixed point (bearings, yes, they have tolerance and losses) linked to a relatively high mass.
We have a second point that is elastically suspended and is vibrated mechanically (stylus and cantilever) linked to a second relatively moderate mass. Multiple resonances happen on the small stylus/cantilever and moderate mass system, including stylus/vinyl resonance and any structural resonances of members of this system.
For the best accuracy in the stylus tracing the information cut into the groove the second point is absolutely unmovable, but other requirements of the LP system require relatively free movement of second point in the lateral and vertical planes at very low frequencies (<<20Hz),
We have a structural member linking these two points, which can either be made in a single piece (with a variety of geometries) or in more than one piece.
If more than one piece is used commonly the structural break(s) occur near the two ends of the structural member. They commonly use some form dissimilar materials and press fit. At the energy input end the press-fit is often combined with a compliant elements that creates tension in the press-fit.
Which system is better able to damp unwanted resonances in the input system? Rigid/same material, or non-rigid with multiple materials?
My Ortofon Arm has the counterweight suspended by rubber, creating a lossy, damped coupling resisting movement at higher frequencies in the whole system.
Do you maintain my understanding of the systemic issues if wrong?
If so please correct me.
Thor
You need to go back to study the maths and look at what happens when you have distributed mass, lumped mass, elasticity and damping and what happens when you make a new dynamic system by joining 2 separate systems together. It is complex.
They can not be considered separately in a dynamic situation and since a record player is a vibration (groove modulation) measuring device the whole system needs analysing as an assembly.
Pickup arms and cartridges being sold separately is a historical artefact of the business, not a sound engineering based reason.
Anyway years of study are needed to understand the maths (it was for me) and get the analysis right and I am not a teacher, just an engineer with 50 years exasperating experience of resolving dynamic system unexpected responses when they were assembled by people using quasi-static thinking.
