Alou
- Joined
- Oct 21, 2019
- Messages
- 146
- Likes
- 53
By the way looking at specs the input sensitivity is 1.6 mv ,my other amps are at 2 mv.
You would probably say and you will be right that the difference is marginal but just for informational purposes is there an adjustable gain in these amps ? I think some other makers offered that might it might be in other ncore boards.
I dont know much about NCORE modules, besides reading the company info and whitepapers.
Also the buffer boards and the op-amps on it are offered in larger board only ,i am asking because i saw some makers offering variable so called buffer boards ,but seems its only for the NC500 or higher. Also since i read in another post that these get hot ,after a 4 hour playback is was at the same temperature when i opened it ,no thermometer just feeling it by hand ,If you take in to acount that a daily session ,for me at least is no more then 3-4 hours ,this amp is not warming up at all!! Thats really good.Also there is no noise or S/N noise heard from any tweeter even at ear level.
Extremely Silent ,if you dont see the light you dont know its on!
