Incredible Sound Quality and Mediocre Build + Comfort or Mediocre Sound Quality and Incredible Build + Comfort
HRTF_Enthusiast
I must preface this by saying that both headphones are low distortion and can be EQ'd to anything. I felt that this would bring an interesting discussion because personally, I view stock response as an art form. Why buy a headphone that requires EQ to sound good when you can buy a headphone that sounds good without EQ?
This then leads to factors outside of sound quality. How much do you value build and comfort? Would you get a headphone that sounds mediocre out of the box over a headphone that sounds incredible for a build + comfort upgrade?
Firefly00
New Zealand
If it can be EQ’d to anything, then the sound out of the box is irrelevant imo
”why buy a headphone that requires EQ to sound good when you can buy a headphone that sounds good without EQ?” Because of the ’incredible build and comfort’
or just take a slight compromise on both!
Malaj
EQ can´t solve everything far far from it. If so I would still own my koss porta pro.
I also like to use headphones that sound good and you don´t have to take to absolute extreme measures to get to perform decently.
I think the poll is a bit extreme. Better would be incredible vs great instead of incredible vs mediocre. Wonder how many here would settle for mediocre sound. You can if you are running and sweating etc and can´t really put full attention to the music so for the portable athletics scenario I could possibly vote for mediocre sound but then it has to be incredibly cheap and well you can get above mediocre sound for not a lot of money.
I would put koss porta pro above mediocre in sound quality but well they are not super comfortable in the long run. That said I would take the yamaha eph-100 anyday though comfort might be a bit worse in the long run with all the ear sweat :)
Tup3x
Finland
There's no point in sound quality if the headphone is a torture device physically.
Jimbob54
As a theoretical exercise with no downside to EQ then it's comfort first every time. Build quality in terms of robustness I'm not as fussy about but comfort is an absolute must.
Stock sound in this case is a little moot.
Chester
If you had asked me that when I first got into all this, I would have said instantly “sound quality….if it happens to be comfortable, it’s a bonus”.
Several years later you realise that with the goal of enjoying music in mind, comfort is a very important consideration. My Grado PS1000E’s taught me that lesson very quickly. I would probably pick comfort and EQ’ed mediocre sound, today.
Why compromise though, plenty that do both on the market.
Yasuo
I think this should apply only to speakers, because for headphones you also must define the purpose; for instance for commuting I would chose build quality and comfort (features as well, dare I dream). But if I'm at home, then I want the best sound quality possible as I want to enjoy it at "reference" level.
Jim Matthews
Taxachusetts
I wear glasses for reading "cheaters" in North Muriccan.
My venerable Sennheisers have remained in use because the earliest are both comfortable and replaceable. Highest fidelity? Not likely - I tried Stax electrets years ago which were detailed, nuanced, reasonable bass response and excruciating to wear for any length of time.
I also think cable compliance is important - favoring cables that are connected to only one side.
Firefly00
New Zealand
Well, if you don’t like your PS1000E, I’m qualified to safely dispose of them if you‘d like to send them to me!
Chester
Long traded for something better. They certainly held their value which was a plus.
H
HRTF_Enthusiast
I said low distortion
Malaj
So the idea is you can get incredible sound quality with eq and mediocre comfort vs incredible comfort and incredible sound quality. Then there is only one choice I suppose :)
ZolaIII
Bahhh, good sound quality and deacent build quality at a decent price and then we can discuss other preferences.
Even comfort can be seen differently as physical/environmental...
All hedaphones are unpleasant to certain amount and much more in certain conditions, conditions sometimes dictate design purpose, all designs have their flaws. Questions is where and how you want to compromise. EQ - DSPing to the end of the world is not a solution but pretty much the opposite (re-mixing).
H
HRTF_Enthusiast
No. Incredible sound quality without EQ and mediocre comfort vs incredible sound quality with EQ and incredible comfort
Robin L
1 mile east of Sleater Kinney Rd
This is not an either/or proposition.
As far as I'm concerned, the build quality of my gear is more than good enough without being arrogant about it, the sound quality is as good as one can reasonably expect within moderate financial limits. I want my gear to work for a long time. I'm not in the habit of thrashing it about.
H
HRTF_Enthusiast
Maybe phrasing it this way will be easier. Headphone 1 has mediocre build + comfort and is at the theoretical limit of sound quality out of the box while headphone 2 is at the theoretical limit of build + comfort but can only reach the theoretical limit of sound quality with equalization.
Robin L
Nope. Unless my Drop 6XX is required to play back the bottom octave [pretty rare, given my tastes in music], they play fine without eq. "Perfect" is not an option, never was.
I think you may have created a straw man.
H
HRTF_Enthusiast
It's a theoretical scenario...i never claimed such a headphone existed
